  • Replies 951
It all sounds good, I'll be watching for the next one.
Haha, a NSW event morgs can drive to, he'd be loving it :)
Should come down as spectator and you can passenger in the cars at the event, still great fun and you get a feel for the event for next time....
LOL
The next DECA will be in November :)
But we are having our own NSW (texikhana we are calling it) one in Spetember 16th at Sutton Rd :bunny:
LOL
Texikhana because its close to mexico! haha
you need a licence to drive, like corey haim in the classic
licence to drive - http://www.imdb.com/title/tt0095519/
in actual fact corey haim and feldman both didnt have licences while they were making this movie
lol
Not long now paul! :sorcerer:
PS. My question still isnt answered. lol
You are also required to have the following;
1 Skylines Australia VIC Membership
2 Helmet for yourself (required on short and long track, not required on skid pan)
3 CAMS or AASA Membership for Insurance Coverage
hmm I dont have 1 and what is 3 ? :rant:
So is Kelly in for spectating and going down with you in your car?
Nope, shes being weak
Hi guys,
Due to some personal issues, I will no longer be able to attend DECA.
Sorry :P
Oh thats a shame Corinne...was going to drink a big magarita with you! and were the chick team
Oh? Weak? I'll weak your face! Maybe I will come to Deca... maybe I wont.. or maybe I will... :thumbsup:
Oh I hope you are!!!
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
