  • Replies 951
It all sounds good, I'll be watching for the next one.
Haha, a NSW event morgs can drive to, he'd be loving it :)
Should come down as spectator and you can passenger in the cars at the event, still great fun and you get a feel for the event for next time....
LOL
The next DECA will be in November :)
But we are having our own NSW (texikhana we are calling it) one in Spetember 16th at Sutton Rd :bunny:
LOL
Texikhana because its close to mexico! haha
you need a licence to drive, like corey haim in the classic
licence to drive - http://www.imdb.com/title/tt0095519/
in actual fact corey haim and feldman both didnt have licences while they were making this movie
lol
Not long now paul! :sorcerer:
PS. My question still isnt answered. lol
You are also required to have the following;
1 Skylines Australia VIC Membership
2 Helmet for yourself (required on short and long track, not required on skid pan)
3 CAMS or AASA Membership for Insurance Coverage
hmm I dont have 1 and what is 3 ? :rant:
So is Kelly in for spectating and going down with you in your car?
Nope, shes being weak
Hi guys,
Due to some personal issues, I will no longer be able to attend DECA.
Sorry :P
Oh thats a shame Corinne...was going to drink a big magarita with you! and were the chick team
Oh? Weak? I'll weak your face! Maybe I will come to Deca... maybe I wont.. or maybe I will... :thumbsup:
Oh I hope you are!!!
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
