  • Replies 951
im still planning to go down early, so ill also be in for Winton, basicly to run the new engine in since the car is unregisteered and there is basicly ill get no free track time before august up here.
Ill be towing down with the ute if anyone still needs stuff carted.
pfft to 180 drivers :sorcerer:
you're turning Green Ash!!!
When you drink those with Team Wang - they are referred to as Wang Busters! :P
Will be ace to catch up though.
i thought they were Wang Bangers!!!! lol. They now form a part of the staple diet up here in NSW (especially when Dave, Anna, Bunta and I are on the piss!
Um Steve'o I think you mean.
you have that every day dont you stevo ahaha
:laugh:
Oh I would.. but im WORKING.. like at WORK. Plus I wouldn't want to get shot by the snipers while trying to cross the hallway.. Come on, I had to army roll down the stairs this morning just to make it safely to my car :D
*sigh*
So what is the lineup now for the Winton/DECA half of the group?
Cars
TJ
Sam
Liz
Risking
Riders
On second thoughts, I've just found out that the Winton day is the day before the Winton 1hour race, so that track day is going to be packed.
Duncan said that it already gets pretty full given it's only $50 and a short drive from Melbourne... but I'm not sure how good it will be given there is some racing the next day aswell.
Liz.
Owwwww - that sarks Corinne :(
LIZZZZZZZZZZ - you coming or what??
Hi Smoky :P - lol
And for anyone who missed it:
Hi Bec :D:)
Im with you there Ash :)
I think Liz will need the 180 towed home Brad :(
Liz.
Who ever told you your facts you need to ignore from now on.
The weekend of DECA (Aug 25-26) is a round of the AMRS at Winton. So IF there is any cars there practising they will be pretty cool to watch. But given Winton does their Friday's in 3 groups of 20mins (20mins Bikes, 20 mins Racecars and 20mins street cars) the amount of track time you'll get won't change. But I doubt there will be many there given the Saturday is practise for the AMRS cars anyways.
Plus it's a $100 and its 3hrs from Melbourne so I've never seen more than 10 cars there on a Friday - although this may have a couple more given it is the week before Dutton Vic and few cars could be out for a shakedown / giving co-drivers a test run behind the wheel. But you will leave the day with more than enough laps under your belt to have made it worth while.
Number 1 - Comes through with the goods again..
Snowy is correct here people.
Smoky - got a car yet?
Its on bricks at the moment :( my coilovers have been sent away to be reconditioned.. once they are back in.. the gearbox is going to be sorted out by then.. im looking at heading down to Winton with you guys actually :P make the trip worth while :)
Yea he does, pitty he still can't drive.. :P
And you can talk?? :huh:
Just another to a long list... :nyaanyaa:
Remind me to punch you in the ovaries Wayne :P
oh no the fu(k you didn't girlfriend!!!
I think he did Lizord!! :laugh:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
