VIc guys,
can you please confirm our payments?
cheers!
I will chase people next week if I can't find there payments.
For now I need to see an entry form from the following:
25 Shawn (Smoky)
29 Liz (Liz)
30 Brad (Risking)
33 Jen (Tripin)
34 Wayne (DJ Brave)
I have received an entry form from:
20 Stephen Hugh-Smith (N1GTR) Supra RZ
21 Iain Anderson (A31Deviat) Cefiro
22 Nicholas Smyrnios (INTUNE) GTR
23 Victor Huang (d00dz) R33 GTST
24 Chris Quick (evil weevil) R33 GTST
26 Jessica Hearne (Sinful) GTR
27 Andrew Hearne (nuttshunglow) GTR
28 Anna Burns (msnismo) R33 GTST
31 Timothy Andriesen (tjandriesen) R33 GTR
32 Samual McDonald (SAM916) R33 GTST
  • Replies 951
25 Shawn (Smoky)
29 Liz (Liz)
30 Brad (Risking)
33 Jen (Tripin)
34 Wayne (DJ Brave)
Sweet but does this also indicate you have recieved the $75 as well?
Its ok...... I only booked 1 cabin for 3 nights and now there is more going then expected...
Nope you and Jason are in Cabin 2 for 2 nights and Cabin 1 for 1 night...
Yep I will need you to pay the differnce please >_< and which steve are you talking about?
There is always the couch if really needed and only for one night........
Tops!! Thank you so so much for the massive effort you have put in Jess for getting everyone a roof over our heads! I will be buying you a drink fo shiz!
25 Shawn (Smoky)
29 Liz (Liz)
30 Brad (Risking)
33 Jen (Tripin)
34 Wayne (DJ Brave)
20 Stephen Hugh-Smith (N1GTR A.K.A. Fagman) Supra RZ
23 Victor Wang (d00dz) R33 GTST
Form faxed and payment made today :)
Has Steve-o payed his additional handicap fee?? :P
Looks like the taxi and poopra will have to knock off some skyrine's........ :P :sorcerer:
*ponders ways to sabotage the skyline syndicate* :)
dude, remember Im the one from NSW to beat :)
check results from last time hahahaha
Ha, mate your too easy to sabotage... give the evil one a few bourbon colas and he is up for anything....
But i will ensure my tactics are aimed towards you then!!
Why do you need to sabatage the skyline's, are you scared you will come last.....
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
