what would be 1 next size up, or even on par with it just in dual bb
i wanna hit 450rwkw without having to pump 30+ psi through it
t04z .84 or 1.00?....it has to be a split pluse housing
its going on a full built rb26/30
ben...
Edited by 2BNVS
https://www.sau.com.au/forums/topic/174659-trust-td07s-similar-turbo/
just prefer the newer technology
dont believe the hype is all i can say. ive been using hks garret and Trust for years and if you get the trims and housings right the core differrence is worth nothing. in fact most bush turbos actually last longer than the generic garret rollers...
thanks for the advice mate, i do appreciate it... just one of my mates can get me great prices on the t04z's and is also making my custom manifold using his jig for a t04z... so i was just seeing which out of the .84 and 1.00 would be better for 450rwkw say on 30psi nothin more....
cheers...ben.
i must admit the T04z is a nice piece of kit.. what mods you running? i will look at the specs.
Off the top of my head i reckon the 63TA/R1.00, because you state you want to make as much power with as little boost as possible.
Are you looking at the garret version or the HKS? they are differrent
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
