what would be 1 next size up, or even on par with it just in dual bb
i wanna hit 450rwkw without having to pump 30+ psi through it
t04z .84 or 1.00?....it has to be a split pluse housing
its going on a full built rb26/30
ben...
Edited by 2BNVS
https://www.sau.com.au/forums/topic/174659-trust-td07s-similar-turbo/
just prefer the newer technology
dont believe the hype is all i can say. ive been using hks garret and Trust for years and if you get the trims and housings right the core differrence is worth nothing. in fact most bush turbos actually last longer than the generic garret rollers...
thanks for the advice mate, i do appreciate it... just one of my mates can get me great prices on the t04z's and is also making my custom manifold using his jig for a t04z... so i was just seeing which out of the .84 and 1.00 would be better for 450rwkw say on 30psi nothin more....
cheers...ben.
i must admit the T04z is a nice piece of kit.. what mods you running? i will look at the specs.
Off the top of my head i reckon the 63TA/R1.00, because you state you want to make as much power with as little boost as possible.
Are you looking at the garret version or the HKS? they are differrent
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
