The epson ej1 is the ecu for the LCD screen right?
Basically one that is the same as what you have in your car - displaying oil pres, boost, speed, rpm, the whole works....
Do you know the jap sites that still sell them?
Yeah, if you dont have the ej1 then the screen is only use for as a tv or reversing camera or some thing like that.
Also there is no oil pressure or boost pressure, it has rpm, speed, power (how it gets the power im not sure but it was pretty close), gforces for accelerating and breaking (no side to side) and then a whole heap of pit stuff that somehow gauges tyre wear and other stuff.
I didnt like it and got rid of it, wasnt really what i wanted, was just a little gadget to tinker with.
Dont remember what site still sells them, will have to do a search.
So basically without the ej1 the screen can only be used as a tv or something like that? I didnt think you needed the ej1 to display speed, rpm, etc.
What does the screen on your dash display?
You can use anything which has a video output; so HKS CAMP 1 or 2, blitz have something similar also, or ej-1 system
there is one for sale atm but at 1.5k+ (no ej1 system but its the sat nav one)
the screen is just used to display anything (has a video input at the rear of the dash)
Edited by Kaido_RR
What i meant was the hks camp wouldnt work in a skyline, but that lists a cable for the consult port so it should, but only if you still have the standard ecu.
Also i would take note of all the extra bits needed at the bottom of the page you linked to (unless it will all work through the consult port) that was exactly the sort of thing i was looking for, pitty no one told me about the consult port cable back then, just thought it was OB11
Well i guess i better start putting away some $$$ just incase i come across one!
there are 2x Dash for sale atm both are the sat nav price (between $1500-$2000) then there is a brand new epson ej-1 system for sale too price is $600
not cheap :P
HKS CAMP 2 is $650 + $50 for the plug for the nissan + if you any optional sensors they are $150 each (boost, pressure, temp)
but the display is better
Edited by Kaido_RR
read don't need as : Doesn't help you go faster, could be done cheaper with other alternatives, if you don't already have it why bother.
So what your saying is that everyone should do the same things with there cars, no one is allowed to be different or do something that you dont agree with, not all people just want to go faster, most people understand this but there are still some who think modifying a car is all about doing it there way and every other way is wrong.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
