Out of interest...
What mods have you guys got?
What petrol do you fill 'er up with?
How far do you get on your tank?
Auto or Manual?
City or Highway driving?
I've got a catback Impul Exhaust, Impul tuned ECU, K&N Air Filter.
I've been using BP ultimate extreme or whatever they call it.
Averaging around 450km's to a tank.
Auto
50/50 City and Highway
Edited by ScottKing GTS-4
https://www.sau.com.au/forums/topic/174972-v35-coupe-fuel-econemy/
  • 1 month later...
Just got 648kms out of the last week n a half! :)
Driving to Byron Bay sitting on most speed limits I got 12.3 km/l or 8.1l/100km. Around town I get about 9.6km/l which is excellent from a 3.5l engine and 1550kg - results due partly from the low Cd of 0.28 and zero lift aerodynamics
  • 1 month later...
Hi consider this.
My one shows up 6.4km/l or 16l/100km in sydney daily driving is way too high????
Does any one has any idear what is going on with that? Proberly with O2 senser?????
Hi consider this.
Does seem quite high Frank,
I'm sitting on around 9.4km/L in sydney traffic. That's taking it quite easy though. But I love it, 70km's a day and the guage only moves a notch or so per day.
Cheers
Bobby
Cheers
Bobby
Yeh, I think I need to get some details check as i am way to much on fuel,
What I am afraid is something in engine is wrong.
I need someone in inner west good at Skyline/350Z to check it.
Bobby, do you has any idear?
send "scathing" a PM. He's had a bit of work done on his 350z so should be able to point you in the right direction.
  • 7 months later...
I have regularly been getting low 7's according to the computer over the past couple of months, all city driving, bumper to bumper, barely moving an hour each way. Is this where it should be, or is it too low? When I do get to drive on an open road (i.e. late at night), the economy is much better, around 10ish, so I'm assuming its just due to the traffic.
This is an interesting thread...
What driving styles do you guys use? If manual, what RPM do you shift at.
Also, what can we do (besides babying the throttle) to remain as economical as possible when not fanging around? Any good fuel economy mods?
Has anyone used anything other than 98 RON? The Yanks use 91 and seem to run fine?
US fuel is different as it has a different rating system. Off the top of my head I believe that 91 is close to the 98 we use.
My car is achieving fantastic fuel economy, with average klms per tank getting up in the very high 500's (without the fuel light glowing when filled). I recall one mid to high 600's tank, but that tank had a few fair few highway klms. I would love to do an open road trip as I am sure 800 could be possible.
I am fairly good, maybe baby it a little too much at times. I find that it does not need a lot of revs to get the job done (however do not under rev). I must look at my average shift points, as I do it more by sound and feel than anything else.
Hey Graeme,
Yep I would agree, and am getting pretty much the same. When i had the auto i drove from Sydney to Canberra, reset the fuel computer and it said on a full tank i would get 800 and something, so your comment is spot on.
Ahh, I didn't know that about US fuel, but Wikipedia to the rescue:
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-92 in Europe. However most European pumps deliver 95 (RON) as "regular", equivalent to 90-91 US (R+M)/2, and even deliver 98 (RON) or 100 (RON).
According to this, US 91 RON is close to our 95-96. Interesting.
Are you doing City kms for the high 500s??
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
