Hey Guys,
I am having drinks for my 27th Birthday on Friday the 13th of July (Actual Birthday on the 9th)
Would love to see you all there
When: Friday 13th July
Where: The Brisbane Hotel - Cnr of Beaufort and Brisbane street Highgate.
Time: 8pm onwards.
So come down and say hello. All welcome :)
Dan
  • Replies 82
Sounds good aye, but I'm a bit new, I'm not familiar with the SAUWA community... I wouldn't want to be 'out of place'.. I might give it a pass...
Hope you have a good one mate!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
