hey guys, just bought my first turbo car which is a R32 gts-t and have some general knowledge about it but would like to know what are some good basic mods i can do to get the hp up. Not looking for huge amounts of power just yet but would like something around 250rwhp for now. Had it dyno'd a few weeks back at Hyperdrive in Malaga, good shop btw :thumbsup: and it made 190rwhp on 9-10psi which i have had turned up to run 13psi on high boost setting which is making 208rwhp.
The mods it has now are:
cat back exhaust, which im planning on finishing soon.
K&N air filter.
larger fuel pump and tank.
Frount mount intercooler.
Heavy duty button clutch.
Profec B boost controller.
Greddy Type R/S BOV.
So as you can see its pretty stock and would appreciate any feedback.
Oh, will try and get pics up ASAP
Edited by Zell
https://www.sau.com.au/forums/topic/175239-first-turbo/
well firstly welcome to the world of skylines and to the forum :O
basically the next thing you should be doing is finishing off the exhaust, should reduce restriction and hopefully gain some hp there,
im guessing after that you should be looking at a type piggyback ecu or depending on your budget a standalone system (good luck finding a power fc :thumbsup:)
one main thing to remember on these forums is to use the search function, which you will find to answer a few of your questions.
sam :D
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3211470
Nice mate, I just got my first turbo (RWD car for that matter) last week. While on the subject of mods does anyone know the price I should be paying for a decent fmi, I seen a hybrid kit they anygood for I think $900 diy? Because Im looking at getting the 400R front which is $995! wreckers anyone? Dump pipe hey ill have to look out for one of those.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3211783
900$ for a hybrid sounds like you are gettin ripped
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212196
Yeah lots of people with RB20s seem to think the rb25 turbo makes a great difference.. wont cost too much either. Quite often people on here are selling them for $200 - $400ish. While you putting that on get the front/dump pipe done to finish your exhaust off :D
My cooler was $550(DIY) from autoworx.. its about 76mm wide and didn't need to cut the 400R front bar.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212310
Alright cool. I just found the exact same fm for $450 brand new so I might get it from there. Cant beat Paul for service though and knowing his skylines! (almost bought a car from his but didnt). Where abouts did you grab your 400R front bar from, and what price roughly? If ya dont mind me asking.
Edited by Dani Boi
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212406
My car came with the 400R front, just fitted the matching 400R side skirts from mitchy's wreck.. rear bar OR maybe just pods are up next. I did see a full 400R kit on ebay, can't remember how much it was but I dunno if I would trust something from ebay to come to me without something being dodgy or it gets broken..
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212485
hey guys, thanks for the feedback. Now have a good idea of what is needed. The RB25 turbo i have also heard seems to run fairly well on the RB20, anyways finally got a chance to take some pics of the car for you guys to see :D. For some reason the pics seem to take for ever to upload onto this post so i have stored them in my gallery. Not sure if i need to add a link here somehow or if you guys can just look me up as a member and see the gallery that way
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212944
if i were you i would go for something bigger than the rb25 turbo.
if you go to the effort to change the turbo, may as well put something decent on :(
and 250rwhp will be pushing the thing
Effort? it took 2hrs to do my swap and it was a direct swap, the only other thing that would be as easy to do is to buy the rb25 turbo and get it hiflowed before putting it on.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3214484
direct swap? doesnt the oil feed banjo bolt on the 20 lines have a bigger hole? or did you use the 25 lines?
why are you asking about a front mount intercooler when the pictures already show one??? i'm confused
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3214752
Car belongs to Zell, and Dani Boi is the one askin about the cooler.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3214780
I have heard this too but maybe I just got lucky, everything was a direct swap - I have a series 1 RB25 turbo with the steel compressor wheel so that could be why. Straight swap, easy as coz we did it at my mates workshop and he's pretty cluey with RB motors. The hardest part was wiggling the old turbo out and the new turbo in ;)
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3215925
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
