hey does any one have neons i am prob getting some, was speaking to the guy at autobarn he said they sell and install them their but he told me he has some off ebay on his car cost him around 150 and he instaled em himself reckons its really easy, any one else bought them off ebay/ installed themselves alos got any pics of skylines iwth neons
cheers
https://www.sau.com.au/forums/topic/175319-neons/
Did you goto school mate? You seem to struggle using a keyboard for some reason.
Neons are
1. pretty gay
2. A final ( final cosmetic mod) that you CAN do to add 5 stars of wank to your machine. I'm pretty sure i'd only add some if I did have some crazy yellow, pink or green paint job.. but your call.
Get the cheaper ones.. they all do the same shit, light up gas inside a tube .. you just wire it directly to the battery
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3212783
Maybe spend the money on some engine mod's first and once you have owend your line for a bit you will see what a dick you would have been with neons on your car.
thats my 2 cents
But the end of the day it's your car
Edited by cruzin33
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3212796
i can f**king spell i can prob type faster than half the people here but when i type really fast i f**k words up lol, ill prob have people having a go at me on this but im mainly into looks not speed :D but yeah i think they look pretty cool hahahahah any way any one else got any opinions
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3212870
I love how everyone finds the time in less then 3 hours to be a dick... why not be a man and find a thread that you might be able to solve?
I have neons on my car... MY car, its not yours, i dont have to do what you say...
that being said, i never use them anyway... maybe once or twice when parked in a crowd... installation is easy as, and the LED ones dont break as easily, they allow a bit of flex... and one small crack in the tube doesn't mean you have to throw them away... getting an even spray of light on the ground is hard though...
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3213934
dude i got neons on my ride
theyr easy to install i just hooked it up to the parking light/head lights so wen u got the parking lights on or watever u can turn them on. I also got a button which u can turn them on/off manually.
and im the same as drd-00f i dont really use them that much except wen im around ppl u kno
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3214320
Why is it every week we have someone asking about neons to put on their skyline :)
Your car buddy, do what u want, but i suggest doing a search on stuff like this first because A: Its been covered a million times and B: You will get smart ass responses because 90% of ppl on here think they are a gay thing to do under your car.
But to help in your question, yes its relitevely easy to wire them up as long as you know what your basically doing, cause you really dont want an electrical fire in your car.
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3215292
www.varad.com or the aussie distributor i think is
www.darav.com.au
I have these one. Have had the for long time and had no problems. I have the colour change ones.
With the sqaure tube design of these they are less prone to damage.
Need any more info on them, PM me ;)
Cheers
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3215601
i had neons on my old car and had them hooked upt o a custom made switch board in car with two switches one for undercar set and one for interior set
PM for more details....
Dont have them on my new car tho so have two sets laying around
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3216031
I have got a couple of those 30cm slimline Cold Cathode tubes off ebay in the "computer section". They are easy to wire up and give off good light. By the way i only got them to light up the area where ur feet go to help ya see where ya feet go at night when ya open the doors.
Also i replaced the boot light with a brighter Cold Cathode tube also. Makes it a hell of a lot easyier to see what ur doing in there. Specially when ya have to play with amp settings etc at night.
I think that they can be usefull. I intend on getting some more to put under the bonnet so that if ya have the hood up at night workin on the car you can see what the hell is going on.
Good when used in a practical sense.
My 2 C
https://www.sau.com.au/forums/topic/175319-neons/#findComment-3216610
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
