Hi guys,
I'm looking at buying some new wheels and am thinking about getting some TE37's.
The sizes I have chosen are (F)18x8.5 +22 and ®18x9.5 +35.
My question is, what will these wheels actually look like? As in the angle of the spokes? Will they be tapering inwards slightly (similar to a GTR offset but not as aggressive) or will they be totally flat faced?
Cheers
https://www.sau.com.au/forums/topic/175369-volk-te37/
The spoke angle kinda depends on the rim width and offset, so if they are huge (like mine) they should have a good angle, thin wheels will be flatter. The ones on mine are 9.5s, so you should get a pretty good angle
https://www.sau.com.au/forums/topic/175369-volk-te37/#findComment-3214520
you will have a flatter offset for the rear and a really aggressive spoke angles for the front
those are very odd sized offsets to choose...make sure you get it right before buying them, id be looking at going something closer to +30, +28 or +25 for the rear...use the offset calculator to figure out how far you will need to go!
Edited by hawker05
https://www.sau.com.au/forums/topic/175369-volk-te37/#findComment-3214589
Hi guys,
Thanks for the replys.
hawker05: I agree with you about going something more like +30,+28,+25 for the rear but for 18x9.5 TE37's there is no offset between +22 and +35. I think +22 may stick out a bit too much, but would have the aggressive look....
I was also thinking about 9" wide but in 18's there is ONLY +40 :thumbsup:
Anyway here is the TE37 size sheet, if any one has any other ideas..
Cheers
https://www.sau.com.au/forums/topic/175369-volk-te37/#findComment-3214680
Just ordered them on sat...
I ended up going 18x8.5 +22 18x9.5 +22 Bronze. The back will definately need some pumping and maybe also a bit at the front.
Heres a pic of my car, should look something like this :P;) (dodgy Paint Shop Pro)
https://www.sau.com.au/forums/topic/175369-volk-te37/#findComment-3219294
  • 3 weeks later...
lol... he got them from japan :action-smiley-069:
Which means... since volk are backlogged with orders, he will only get them in Jan next year. Worth the wait tho
PM Blackzila if you looking for the japan contact. He is a pretty good guy, and really helpful too. Can get you just about anything
https://www.sau.com.au/forums/topic/175369-volk-te37/#findComment-3258171
