Hi, Was just reading http://www.skylinesaustralia.com/forums/in...howtopic=157983 and http://www.skylinesaustralia.com/forums/in...howtopic=149405.
Just a few questions if anyone can answer.
1. What is the wire size from the fuse distributor to the (+) positive terminal? I think it's 4G?
2. How hard is it to remove the O-Ring from the fuse distributor and replace the wire with a new one? How?
3. Grounding spots, where in the boot is a good grounding spot for an AMP? You can use the std battery ground mount?
4. 8G and 4G which is better for ground (-) and (+).?
5. The metal plate where my battery sits on is all corroded (It was like this when I got the car) Ive been running at GEL battery and it hasnt leaked so the corroed metal is just sitting there. :( is this bad?
The reason why I ask 1 and 2 is because, currently the wire from the distributor to the battery (+) terminal is very short I have to move the battery even tilt it in order to connect it. And I want to either replace the wire or grab a Gold Plated Cable Joiner.
What should I do?
Thanks.!
https://www.sau.com.au/forums/topic/175403-battery-and-power-boot-info/
1. 4GA
2. removing, easy, replacing, not so easy... you will need a crimping set, and its a pretty big lug... best bet is to find the right size lug, and ask someone at jaycar to put it on some 4GA for you... no point buying a crimping set if you only use it once :thumbsup:
3. yes, or even the terminal if its just as close... if your going to make your own, make sure to get a good solid connection, and sand any paint back...
4. 4GA the bigger the better theoretically...
5. If the battery is sealed i wouldn't worry about it, it seems like a previous battery has corroded... keep an eye out for a replacement though... or get that one sand blasted and painted if its not too bad...
the cable joiner is a temporary thing... it also seems to be bare metal, which is bad for a positive wire in a negative car... get the right size ring on some long 4GA and replace the standard one...
Hmm thanks!
Guess for the time being Ill just charge the battery up and connect the wire via the terminal screw down lock thingys. Then fix everything else later..
I just wanna drive the thing!
Do you have any pictures of the O-Ring or what it looks like connected to the fuse distro and/or when it's out?
Hmm thanks!
nope, but i found my camera the other day, and i just may be able to take a pic for you when i get home if i have enough time :bunny:
thats a big if though...
lol.. it's ok I got worked on my car all day today fixing wiring and other crap.
I managed to get The 4GA out of the fuse box. It was pretty easy, just one bolt connecting it, 12MM socket.
Gonna goto jaycar tomorrow and get some 4GA longer one and ask em if they can crimp em too. (Hopefully they can) otherwise $70 for a crimping tool :)
Also going to replace the ground wire
Here is the lug..
My (+) wire. LOL so short..
Also here is my battery tray.. Yes very crap ey!? Dont ask me how it got like that, but when I got the car it was already like that straight from Japan.
If anyone know anyone selling that tray let me know
lug is easy. I have those here. how long does the +ve need to be and with what battery terminal on the end.
-ve terminal - 4awg - can make you one if you tell me what you need.
Uhh I went to jaycar and got some terminals and lugs. Rewired the wires and got the 4GA for neg and 4GA for pos.
Also modded the fuse box a bit so that the terminal actually sits to the horitzonally as oppose to the L bend.
Pretty easy, oh man stripping the 4GA with sissors/pliers lol so annoying. (No other tools lol)
I just need a new battery I think, old one is dead.. recharged and recharged and nothing... doesnt store charge.
get a delkor... and yeah, for larger sized wire, use a stencil knife :O
I'm getting a pulse one.
Yea I have a blade knife thingy but it was upstairs and was too lazy to go upstairs and get it LOL
Now waiting for that person who PM'ed me about the battery tray to reply to me, he said he has one in kograh which is close to me. Hurry up and reply! :rant:
After the battery tray i'm gonna rewire the amps and stuff.. :rant:
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
