This was emailed out at work.. not sure how bad it is:
Please be advised that there are lengthy delays on the North Shore, Western & Northern Lines
CityRail advises that trains have been suspended on the North Shore Line between Gordon and Wynyard in both directions due to a train requiring mechanical repairs near Milsons Point. Lengthy delays can be expected. Flow on delays to Northern and Western Line services from the City will be experienced.
Bus companies are being contacted to operate a replacement service between Gordon and Wynyard until train services can resume. Sydney buses recognising rail tickets between Wynyard & North Sydney in both directions.
CityRail recommends travellers delay their journey or make alternative arrangements.
Police and emergency services are in attendance. At this stage there is no forecast of when the line can be reopened. Further information will be provided as it becomes available.
I can see all the commotion on the bridge from my desk. I can't make out the train but I can see all the fire trucks etc. looks like I'm going to be staying back tonight and having a few refreshments.
http://www.rta.nsw.gov.au/trafficreports/i...bourbridge.html
"looks" ok at the moment.
Remember it's school holidays and uni is on holidays too. So just the workers. But yea maybe traffic, sux to live up north!
doodz, no freaking way is that camera live. I'm looking out my window right now and being only about 500m from the bridge I can tell you it's chocka block with emergencey crews etc. the Cahill is even worse heading north (looks ok heading south).
Well that just sucks....working in north sydney and living on the central coast.
Being peak hour there will be a lot of people on the replacement buses.
I guess there is only one thing you can do in a situation like this....go to the pub until the problem is sorted!! If the problem aint sorted, then going home with a few beers in my belly will make the long journey a little easier!
photo is on smh as well.. its not live
Duno.. :) It says "Live traffic camera - Sydney Harbour Bridge" with timestamp ~2mins delay. :blink:
Oh well guess people will be late home and to work.. haw haw :thumbsup:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
