hey ya'll, i like many people have a bit of a crunchy box - gearbox that is.
The most apparent and common crunch is definitely 1st -> 2nd.
we all know it gets better as things warm up, but while it's cold (and even while its warmed up for that matter) give double clutching a go!
you can do it with a little throttle blip if you really want a'la double-down-shifting, but it's not really necessary in everday driving.
instead of just:
pushing in the clutch; and
shifting the stick down through neutral to second
release clutch
do this:
push the clutch in (doesn't have to go all the way)
move the stick from 1st to neutral
release clutch briefly
push clutch in again
shift from neutral to 2nd
release clutch
it takes a while but if you are used to double down-shifting, it should be a breeze. if you're not used to it - it's a great way to get used to the motion of double-clutching and will put you in good stead to start double down-shifting and start saving your clutch and synchros.
i know this has been mentioned before in other "crunchy gearbox" threads, but i thought i would bring some attention to it as maybe there are other people who are nursing their gearbox and/or clutch until they can afford to replace them.
cheers
eh? didnt you miss the step where you blip on the throttle as your in neutral, just before u shift into 2nd?
In cold mornings it wont even shift into 2nd for me. Pop it into neutral, a slight blip on the throttle, and then it easily slides into 2nd :)
yeah i mentioned that you can if you want, but just driving around town, throttle blipping when up shifting isn't usually necessary.
however if it helps your changes i'm not going to tell you not to do it :)
Edited by made_guy
But really, its not how its meant to work, and your gearbox is shagged, its time to look at getting it fixed as all you are doing is masking the problem.
lol yeah a rebuilt gearbox is somewhere on the to-do list.
but in the mean time, best to squeeze as much life out of the current one before it dies ;)
Isn't this general knowledge?
my box is a bit like that in the cold... i could use some new gearbox oil though... very common skyline problem...
i heard that its normally 2nd to 3rd though... i think they said that on Top Gear :)
but yeah, gearbox still works, its just a minor annoyance... no need for a whole new gearbox...
I always double clutch down thru gears in my car. My gear box in my subaru 4WD lasted me bout 420,000km ish before i swapped it out by driving in this style. Mydad used to have the car so he done bout half of the kms but i stretched its life out by always double clutch.
Only reason i took gear box outta the car is because the syncro's were screwed and was starting to get a bit of a handfull to use. Also i had a spare kicking round with only 150,000kms on it, so it only made sense to change the rooted one out.
But yeah i would easy make it too 500,000 kms if i kept up with the double clutchin.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
    • I can't speak for the US, but for Canada as I mentioned above, all fuel gases contain ethanol. We have regulations for E5/E10/E15. Each province handles it differently but basically any fuel gases sold must be E10 and slowly increasing to E15 by a certain year.
