Hi all
im just after some Info on these cars, i am currently thinking about getting another car because i have to offload my R31.
Would this be a good car to drive on ur P's??
And what features can i expect , like HICAS , ABS ??
Cheers
Chris :burnout:
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/
Lucky bastard - wish i couldve had one when i was on my P's
Yeah dude, fantastic car. Nothing too flash just a great RWD, turbo Coupe with plenty of tuning ability and a fair bit of street cred.
Get one with a sunroof - honestly the best feature of my car
They come fully loaded with power windows/mirrors, rear wiper, climate control air-con. The majority come with aftermarket filter, possibly Momo steering wheel and knob like mine did and often a big bore exhaust. Try and get one with full bodykit aswell.
Brakes are good but no ABS. HICAS is std issue but is not a reason to buy the car - if anything it makes the car worse.
Expect moderate-heavy fuel consumption i find 350km to a tank max.
Resale value seems a tad stronger than equivalent R33 but both are good.
Hope this helps!! Goodluck!!
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/#findComment-364513
Here's my Previous cars that I have owned:
TE 250ci 4 Speed Cortina - Great Car Tough fairly quick excellent burnouts but I repaired the Manual Gearbox 6 times. Selector Forks kept snapping and once I had the bearings go.
Owned 2 years. Fuel Consumption 350kays to 50 litres.
VL 3ltr NA 5 Speed Commodore - Gearbox's syncro's were chewed. Slapped a bit of Nulon G70 to smooth things out and sold it. Excellent car not 1 breakage in 9 months of ownership.
Owned 9 months - Fuel consumption 400kays to 50 litres.
VS V8 5ltr 5 Speed IRS SRS ABS, 3.5" exhaust adj. bilstein shocks lowered superlow HD sway bars. Piece of crap car. Rattled and only had 60,000kays on the clock. Broke the rear crossmembed where the diff bolts on. A Clean crack all around the chassis from one of the diff bolts causing the arse end to sit on the groud with around 45degree's negative camber = Tow home. Next was the diff.. Started grinding and felt like a locker. (not one burnout on it either only take off wheel spin) next was the gearbox.. started poping out of gears and bearings were extremly rattly = gearbox rebuild.. I then sold the car.
Owned 9 months - Fuel consumption 430kays to 60-65 litres.
R32 GTS-T Owned close to 2 years now and not one single problem that cost me $$. General maintence shiet like cam belt waterpump at 100,00kays radiator clean etc.. Apart from that the car is extremly tough.. Since I have owned the car It has just kept going and going. I've been running 15-16psi in it for the last year to year and a half. Lots of flat changes in to second that send you wheel spinning all the way through second with 225 50' 16" tyres. A few burnouts.. First quickly click second as you take your foot off the brake and fill the street with smoke.. :)
Owned ~2 years - Fuel consumption 470kays then it hits the red light for approx 50 litres. - City driving no open road driving.
I do seem to get better fuel consumption that others. Not sure why I drive it damn hard and on 15psi. It does have a sort of clear looking top injector with a red dot on it ?!?!?
The R32 GTS-T Is supposed to get 10.5Litres per 100kays which is about what I am getting. If you are in the 300-350kays then some thing is slightly wrong or not quite right. Check your o2 Sensor.. A new one is around 280 bucks. Ouch.
Very tough car though.. Almost unbreakable I am extremly happy with it.
When buying one pull the rear quarter covers on in the boot and stick your hand inside the rear quarter.. If you find dirt water etc.. You know it has most probably had a prang and or the boot or rear window is some how leaking.
Check underneath the car and look at the chassis. make sure it isn't flattened out or gone skidding over rocks due to drifts.
When you open the door check where to sil panel joins with the rear quarter and make sure there is no rust developing. If there is the chances are it has had an arse ender and had a bad repair.
Check the usual door gaps boot gaps light gaps and bumper gaps are all even
Also check the car in all angles with the sun on it, do a u turn and check the other side. It will show up any bodgy paint fix ups..
Better not to have any suprises otherwise you will get it home wash it and spot it.. Then you will be unhappy.. and your throat will sink. :) That happened to the rear quarter in my VS.. Some one repainted it and used to much metalic.. :( Looks bad in the light well I could see it. All the gaps were fine however.
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/#findComment-364589
my gts-t has ABS
ive found the chassis, and drivetrain to be great. lovely car to drive. my experience with the RB20 has been one of a rollercoaster ride, however ive heard the majority of them are bulletproof.
i get around 400k's to a tank, all in all a great little car however can't carry people in the back and all the 32's ive been in have had their own 'quirks' as theyre becoming a fairly old car now
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/#findComment-364632
there have been a few, but yeh running lean was one of them :P
dont let my experiences put you off though, it seems to be a freak case!
they also come with HICAS, but youre probably best off removing it as it isnt the best system. the brakes that come standard from nissan are also very good, as an all-round car it is very good
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/#findComment-364689
Great car! Most of the points have been covered, but theres a couple id like to add:
Sunroof's - Make sure its a factory one and make sure theres no rust bubbling up around it, or you'll be forever repainting the roof.
Gearboxes - the RB20 has a rep for having a weakish gearbox. Unfortunately id have to agree, mine clunks, whines, whirrs and squeals its way through all 5 gears... but its still going and it never pops out of gear so i guess it cant be THAT bad! :)
Climate control - These also have a rep for having dodgy LCD screens, everything works when you press the buttons but the screen just shows gibberish. I know a guy who went through 5 climate control units in his GTR trying to find one with a working screen.
Ive had no problems with mine apart from those which have been my own stupid fault (eg: running too much boost and burning 2 valves).
Red17
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/#findComment-367976
Compared to my old VS V8 Manual commodore that also had IRS the Skyline feels easier to handle in the wet.
The commodore even in the dry use to flick out really quick and was hard to hold in a smooth slide where as the skyline seems to go out a little slower and loves to be held in a slide. Especially in the dry when stepping on the brake through first jump off the brake and slap second pulling out of a corner. :)
They still can snap out very quickly given the right conditions.
https://www.sau.com.au/forums/topic/17568-r32-gts-t-type-m/#findComment-368119
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
