I like my white R34. Only other colour I would buy is Bayside Blue.
I think I will put the Impul kit on soon. MissR34 yours looks very nice.
I will probably remove as much of the mesh in the front bar as possible though(I'd prefer to see my FMIC anyway) and I might keep my current rear bar as Lingeringsoul makes some good points.
Hey guys and girls,
Im currently in the market for a R34 coupe GT-T, for some reason i have found the yellow ones really appealing but unfortunately the few yellow ones i have found have been sold when i have rung up, and the other colour i was contemplating was the white, do you think that the white in the r34 is just meh or is it just me?
Cheers in Advance
Lam
Yeh agree with the white. not a big fan of white
White 34 with Gun Metal or Bronze/Gold wheels looks awesome, then again so do any other colour really... i saw a white 34 with white Nismo wheels and that look very nice also.
rtk post up some more pics of your car with those wheels if you have them,
also, sell me your foggies please!!
Sorry foggies are staying (for now) but you can buy the wheels, they came with the car and i want TER37's.
Above is the only other pic i have with the wheels in veiw.
Well in the end, you could always go for a re-spray, but...
Black is gorgeous and Silver too,
Tell me though, is anyone familiar with the MCR R34, that in its red state looks hot, the only thing i don't like about the Red is that it takes away from the tail lights a little
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
