hey guys
i have a huge problem and im looking for a soloution i have taken my car to a few mechanics who have done some tests and have all come up with diffrent soloutions.
I have an R33 Skyline GTST 1995 with an ARC intercooler 3inch exhaust, Apexi pod and blitz bov stock boost
About 9 months ago i had the car on the dyno and it had 175RWKW but the guy told me that it had exesive blow by and he thought its rings where shot. but said its not a big issue.
I started experiencing misfires on bost and surging also, I thought it was related to the coils or sparkies so i changed them and gapped the sparkies worked for a while then stopped and got worse, It now seems like it running on only 5 cylinders
so i took the car to the mechanic and he said it was rings and pistons as he did a comp test on the car and piston one came up at 50 psi however he didnt check the rest,
I then decided to take it to another mechanic as the car still feels pretty strong and engine sounds imaculate with the exception of a miss which i can hear mostly through exhaust (very lumpy) The second mechanic said it was just rings so i took it to a third and he said its just a blown head and . seems to think its the cause of excesive blow by.
When i took my coils and sparkies out to see if it was the issue i foud the sparkies where rusted which would probable point towards a blown head?? but no water in oil??
just wondering if anyone can shed some light onto this horror situation I dont mind spending money but i dont want throw money away. what do you guys think ???
any help will be appreciated
Edited by daleb4u
https://www.sau.com.au/forums/topic/175908-whats-wrong-with-my-car/
u can have a cut in your head gasket from your cylinder to water jacket and miss your oil gallery's. remove your radiator cap and warm your engine up. if you are getting bubbles in the radiator or excessive water out your exhaust and having to fill radiator all the time it will be the head gone. i had one car that had so bad of a head gasket blown it actually got a hydraulic lock up in the engine and wouldn't turn over. also take the oil filler cap off when the engine running. if excessive air pressure coming out of here that can point to blow by. hope some of this info helps. by the info you have given , sounds like the engine has gone anyway
i have never had to fill up water but when i open it up while its warm i get bubbles as for the oil cap, I get no smoke or air engine feels very healthy and cleam
Do a comp test on all cylinders when the engine is warm.
Also do a comp test on all cylinders when engine is cold [the colder the better], but before you do it, squirt some oil into the cylinder - preferably a heavy oil, gearbox even.
If you get a bad reading when its hot and really good reading when its cold then its rings. If it makes no difference and its low then its guides, valves lifters etc. It could be a bad lifter?
if you had excessive blow by your plugs(especially the one in the cylinder that dropped) it would have been covered in oil.
rust=water
water=head gasket or head
no oil on spark plugs just tips and half of thread rusted as thats why im leaning towars gasket , also the was going great and i take realy good care of it , i service it every 2000 without fail (i know its too much but id rather be safe)
would a blown head or gasket drop comp readings ??
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
