  • Replies 44
Yeah im keen for a meet up, my extractors arrived today, so i should have the full system finished in a week or so :) be keen to get out and see a few more.
awesome..
i'm pretty keen to hear how it sounds compared to stock, if that's possible...
i've been looking at a hi-tech cat-back system..
but after my 3" exhaust on my R32, i want something that isn't anywhere near as loud, rather just something that sounds deeper at idle and at WOT
https://www.sau.com.au/forums/topic/176001-v35-meet/#findComment-3228225
I want something that sounds more high pitched. Love the current sound at high revs. Makes it sound exotic and not a v8 like :). My preference, don't kill me...
Not sure when the meet will happen, but smile back people and give thumbs up back or a wave as a true car enthusiasts if I do it to you... Not doing that does not making anyone any more cooler or look tougher...
Edited by russky
https://www.sau.com.au/forums/topic/176001-v35-meet/#findComment-3228237
Hey,
I'm in Sydney and could be interested, depending on day.
There's a few syd Z's going on a cruise from 350Z-Tech, maybe worth looking into tagging along?
That sounds fantastic, where do we get the details for that?? I want to ask them if its ok if we can tag along. There shouldn't be a problem but its always best to ask.
Nismo how does a Sunday sound?
https://www.sau.com.au/forums/topic/176001-v35-meet/#findComment-3240090
There's an australia forum on 350Z-tech.com.
They've been talking about a meet for a while, but it's been hard trying to get everyone to agree on a date.
"Scathing" who's regularly here, is the moderator over on 350Z-tech. Drop him a line.
http://www.350z-tech.com/forums/Australia-f79.html
Sundays should be ok with me, but I'm in the middle of building a house so once a date is confirmed I'll know more.
cheers
Bobby
https://www.sau.com.au/forums/topic/176001-v35-meet/#findComment-3240190
I'm cool with SAU and 350Z-Tech running a joint cruise.
Plans kind of died in the arse over there for our next cruise, so if you arrange something concrete then I'll post it up (or you can sign up). Our last cruise to Kangaroo Valley was quite well received, and as you can see we had a couple of V35s in attendance.
Since the V35s have been over in the US for ages as the Infiniti G35, you will find quite a bit of info on there as well as english-based tuning guides.
Edited by scathing
https://www.sau.com.au/forums/topic/176001-v35-meet/#findComment-3240554
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
