I know this has already been discussed on here but i'll be stuffed sideways if i can locate the thread!
Now my dilema is that i have a set of 17" 5zigen rims which are chrome....i like the shape of em but not the chrome.....what i am after is, does anyone know of a good place located on the north shore/northern beaches that powder coat wheels.....also can change the colour of em to a dark grey / black..ie Lenso Musa style!
I need them to be fixed up a little..ie some scratches on outer rims need fixing up aswell!!
If anyone has had this done and preferably in the area stated plz post em and a rough price that it cost!!
Cheers
Ando
https://www.sau.com.au/forums/topic/17611-powder-coating-rims/
yellowpages.com.au is your friend ando :D
AB Essence Design Pty Ltd
HEADING:
Powder Coating Services
ADDRESS
77 Whiting St
Artarmon
NSW, 2064
Australia
Ph: (02) 9906 8026
Accent
HEADING:
ADDRESS
14 Wattle Rd
Brookvale
NSW, 2100
Australia
Ph: (02) 9939 2144
B & K Powder Coaters
HEADING:
ADDRESS
22 Ada Ave
Brookvale
NSW, 2100
Australia
Ph: (02) 9938 5609
Brookvale Powdercoating Pty Ltd
HEADING:
ADDRESS
20 Ethel Ave
Brookvale
NSW, 2100
Australia
Ph: (02) 9938 5042
Marble Powder Coating
HEADING:
ADDRESS
Unit 2/ 20 Clearview Pl
Brookvale
NSW, 2100
Australia
Ph: (02) 9905 7486
North Shore Powder Coaters
HEADING:
ADDRESS
10 McLachlan Ave
Artarmon
NSW, 2064
Australia
Ph: (02) 9439 8797
Technicolour Pty Ltd
HEADING:
ADDRESS
20 Waine St
Harbord
NSW, 2096
Australia
Ph: (02) 9905 4911
Vale Power Coating
HEADING:
ADDRESS
D3/ 1 Campbell Pde
Manly Vale
NSW, 2093
Australia
Ph: (02) 9948 9921
Warringah Industrial Spray Painters Pty Ltd
HEADING:
ADDRESS
15 Warraba Rd
North Narrabeen
NSW, 2101
Australia
Ph: (02) 9913 3191
Tosh...mate, cheers!!!!!!!... i finally realise you are good for something;) :cheers: j/k's.....cheers heaps for that i wil get onto them and see what they can do!!!!
BTW has anyone had dealings with any of these companies? If so which do you recommend?
Ando
Memphis u got any pics of the wheels? How much does it cost roughly per rim to get this 2pac ( lol :cheers: sorry couldnt resist ) 2Pak rather, painted?
I'll do some calling around see what prices i can get....compare em to WA :D
Cheers
Ando
Powder coat is a lot tougher than 2pac, something to consider since wheels will get abused a lot more than your panels. ie, gutter scrapes, replacing tyres and wheel weights, even just taking them off and scratching them with the wheel brace.
Does powder coating involve some sort of clear protective coat on the top? I don't want to get my wheels powder coated any colour, I just want the gutter scrap repaired and put some sort of clear coat on the top to give it that 'new' finish.
Have any of you done this? How much did it cost approx?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
