Ermm
Ever since Ive had the car arrive from Japan, the steering has been very very heavy. @ all speeds. It's great for draging at WSID but shitty for windy roads and roundabouts!
Ive gotten used to it but it's pretty annoying now and then..
So what's causing this? (Ive had a search but nothing definiative with a solution.)
1. I think their is enough fluid in there. Not sure have to get it checked out.
2. The steering fluid box broken?
3. Speedo works.... pfc say the pump is working but I dont have the speed reading on the pfc (Only rpm, think the speed wire is cut at ecu wire loom)
4. Blocked lines?
5. Broken power steering?
Can anyone help?
Yes it's not just me other people say my steering is heavy, even Abobob said so! So must be heavy!
https://www.sau.com.au/forums/topic/176264-power-steering/
i would look at correcting this. you may find it magically solves your steering problem. also look in your power steering fluid resevoir and see if there is any fluid in there would be a good place to start.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3225633
Hmm yea Ive been meaning to rewire the ecu. Been lazy for last xx months lol
In the resevor you are suppose to see fluid? Because I think I see some well according to that little guide under the resivor cap it says it's full... hmm will check this on Saturday when there is light.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3225925
nope HIcas light is off... Ive only seen it go on when I had water in my coils and car was jerky.. So I dont think it's the hicas.
I do have power steering but just very stiff like my steering is on viagra or something :)
It may be the speed wire, as Duncan/Richard has said which makes sense ey. I'll have a look at rewiring it soon...
Hopefully this fixed means I can go drift around round abouts weeeeeee lol :)
I'll report back when Ive done the wiring fix!
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3228524
So anyway didnt need to rewire the speed wire, it had one of those connectors..
Now my pfc controller tells me what speed im not going! Didnt happen before.. lawl.
Also checked the resivior and it's full.
Perhaps it maybe the steering line or something blocked in the lines. or maybe the pump is dieing?
go to the gym turd!!
LOL :P
Maybe i'm paranoid, but when I move the steering on Missturbos car and also drove Haysey's car awhile back and it is ALOT lighter than mine! Much like how the rolla steers.
Could it also be the tyres i'm running? larger tyres? But this shouldnt be the case.
dammit! :D:happy:
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3228838
Stupid question..
I suppose you would notice the boiling temps by now..
But if your power steering belt the right size/tightented/not too tight?
Is there enough Power steering fluid?
Pump working?
All hoses connected?
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3231394
  • 2 months later...
having the exact same issue but with the HICAS light on in my r32 GTST
Speedo not working - RPM working
steering is really tight at low speeds
getting it looked at soonish.
any idea how much it should be to get this fixed?? anybody ?? :P
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3359633
I got this fixed...
Problem was...
Power steering pump, the filter was being clogged and hence lower power steering pressure and also it was leaking. Got it reconditioned and car is like a brand new car, ive never driving it with such ease.
Also the soloniod at the steering rack was not grounded properly (not sure what this does but I assume it's the >100 speed to make the steering slightly heavy when at high speeds). Because I notice now that at low speeds steering is easy, then as I get on the hwy the steering is heavy abit to counter the light steering.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3361387
I got this fixed...
Problem was...
how much did it cost? or did you just do it urself?
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3361430
any idea how much it should be to get this fixed?? anybody ?? :D
Your speedo cable is broken. get a new one and install it and it will fix all your issues.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3362014
I got this fixed...
Problem was...
+1 on how much...?
been meaning to get this fixed on my car too - i can see if leaking from the p/s components above the rubber sleave on the drivers side.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3363946
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
