ok......so my supra is shit right? cuz it has to much horse power. so downshift instead of upshifting. ok i got all that, but one thing i have to ask is "what do u mean by brake" is that the regular brake or the e-brake........when i try to drift i use the e-brake....but i'm trying to use the regular brake now to get the feell for it.....oh and another thing rezz.......when i drift my car goes like this...........straight, turns a little to the left/right depending on the angle of the corner, strightens out for some reason, then turns into the corner, stops sliding, gains traction, and then its over......and when its over i'm 3 quarters the way through a hairpin or a big corner........any suggestions on what the hell goes wrong? cuz i sure as hell dont!!!!! oh and for the 240zx what are the setups for it cuz i dont know what to tweak and what to tweak? thx.
  • Replies 134
Alright, I have to ask... whats an "e" Brake?
When I explained my controller setup, I said "brake" is Square button, and "Handbrake" (sidebrake in AmEnglish?) is Cicle button. When I explained above, I meant the "brake", not the "Handbrake"... (f@ck, why was that confusing?)
...as a side note, I'd recommend you don't get into using the handbrake just yet. Get the hang of entering the corners correctly first.
I'd say that when you said "it turns a little... then straightens out a bit for some reason", it's because your allowing the car to regain traction. For a lefthand corner: Approach the corner at about 100km/h (60mph?) and turn full-lock to the right, then full-lock to the left, at the same time you turn full-lock to the left, give it full throttle to initiate wheelspin. As the cars rear end gets about 30 degrees out, countersteer to the right to "catch" the momentum of the rear end. To sustain the "drift pose", keep steering between dead-center and full-lock right, while "tapping" the accelerator button to keep the car at about 30 degrees angle.
Try these settings for the 180SX (240?sx in the US? I don't know):
The Nissan 180SX is the best drift car. The SR20 powered Silvia`s are also good, but the S15 is a little too top endy in it`s power delivery, so to keep it sliding at the limit is more difficult than the others.
Why the 180? Well, the SR in that model (in the game) has the bulk of it`s torque around 3-4000rpm, you need this to be able to tap the accel and get instant wheelspin at lower speeds, and to be able to "steer" the car with the throttle. Also, on it`s lowest ride height at the front, the 180 has excellent stance making the front end really stable... this is apparent in the low to mid-speed corners.
The settings:
SUSPENSION
Spring Rate: (F) 5.2 ®16.2
Ride Height: (F) 89mm ® 89mm
Damper Bump: (F) 2 ® 8
Damper Rebound: (F) 2 ® 8
Camber: (F) 10.0 ® 2.0
Toe: (F) 2.0 ® -2.0
Stabilizer: (F) Level 1 ® Level 7
BRAKES
Brake Balance: (F) 20 ® 15
GEARING
L.S.D. Initial Torque: ® 30
LSD Accel: ® 40
LSD Brake: ® 30
GEARBOX
1st: 3.012
2nd: 2.302
3rd: 1.820
4th: 1.501
5th: 1.245
6th: 0.874
Final: 4.083
Auto Setting: Level 21
ASM (Active stability controller) and TCS (Traction Control System): Obviously set to 0.
*edit* IMPORTANT! Super Soft slicks on the front, with normal tyres on the Rear. Also, fully tune the engine, 500+ps is perfect power, no too much for the slow stuff, and not too little for the high-speed corners like at Apricot Hill.
Explanation: Honestly, keep the Camber set to 10 degrees on the front. This "lowers" the car even more, and it increases the overall track width, giving more stable (and higher speed) drift ability. The gears ARE THE MOST IMPORTANT!!! That box is set. You won`t need 6th, and the other gears are set so close that it provides power wheelspin at any time (just select the right gear for the trackspeed).
well guys i'm bout ready to give up.......i just cannot get it right......lets face it guys. i suck at drifting. i just dont no damn clue as what to do (hey that rhymed). rezz i really need a video thats shows what ur doing.....ya know when u go into the replay options and u can set up this thing where it shows when ur braking and accelarating and steering. if i could see something like that i think i would know what the hell to do.....but until then i just gonna stick to grip driving i think
yes i know that but i need a video that tells me whats happening while there drifting EX: when there drifting around the corner it would tell me whats happening like when to downshift when to brake when to give it throttle when and when not to counter steer. ya know stuff like that
I got the GT Force wheel, but connecting drifts (requiring a furious right full lock-left full lock action) almost had me snapping the wheel off...
...not to mention wierd "handbrake on the steering wheel" button location. Much prefer a real handbrake for sure... aaah Logitech? How bout it?
ok, i have been playing around some more with my drifting style. Still faaaaaarrrr from perfect but getting the hang of it now. Lots of subtle control is required ;)
I'll try and get a video of it over the weekend. Then you can comment on my technique :)
I have found the Mazda RX7 RZ a really nice car to drift.
Will post my setup settings too. Rezz, I really didn't find your settings worked for me... dunno why.
hey i tried a sprinter trueno gt apex (ae86) and it drifts really nice.....only downside is that it isnt very fast.....plus those specs u gave me rezz didnt really work, all the car did was just spin out....i dont know what happened but that 240sx thing just didnt have enough go for me.....can one of u try to find a fast good drifting car?
Okay, I agree with Rezz - the 180sx (or 200SX Type X in AUstralian GT3) is by far the best and easiest car to drift in.
Here are the settings I use:
Car: Nissan 200sx Type X
Mods: Everything
Approx HP: About 460hp
----- Tyre Choice-----
Front: Racing Super Soft
Rear: Normal
----- Suspension -----
Spring Rate
Front: 6.0
Rear: 7.9
Ride Height
Front: As low as it can go
Rear: Just a touch higher than the front
Damper Bump
Front: 5
Rear: 7
Damper Rebound
Front: 6
Rear: 7
Camber
Front: 10
Rear: 0.5
Toe
Front: 0.5
Rear: 1.5
Stabiliser
Front: 3
Rear: 3
----- Brakes -----
Front: 4
Rear: 24
----- Gearing -----
LSD Initial
Rear: 50
LSD Accel
Rear: 50
LSD Decel
Rear: 10
Gear Ratio
I just set this to be about 21 or 22 (auto setup) and then changethe 6th gear to be as low as it will go. This gives you maximum torque in all the gears but lets you stretch the legs a bit on 6th.
----- Others -----
Down Force
Front: n/a
Rear: 0
Traction Control
0
Stability Control
0
This setup I have found gives awesome control of the car. Extremely responsive steering and so much available torque you can spin the wheels in any gear.
For an explanation of drift techniques. It even explains how to do them:
http://www.driftsession.com/technique.htm
I find that my style of drifting is mainly the Feint Drift and Power Over. However I also use the other styles when needed like Braking Drift for slow corners, E-Brake Drift for quick flicks like linking corners and Kansei Drift for high speed corners.
Hope this helps some for those having troubles. I'll try and get some footage of my drifting asap.
gfxman and rezz what i mean by a project car is a car that a few people take and mess around with....like u me and rezz can take...oh lets say a supra and tweak it and see whos specs work the best.....so if u are interested just lemme know. but anywho thats what a project car is
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
