I bought my car from a dealer + when he explained the security in the car he said he'd left the stock immobiliser in + added the proximity sensor immobiliser as well, giving me 2 different immobiliser setups...
If I don't hit the 'unlock' button on my key remote, the car won't start. It'll keep turning over, but refuses to start. It self arms this as well. If I turn my engine off + don't lock the car, I still need to hit the unlock button to disable the security + start my car.
And of course if the proximity sensor isn't next to the ignition, the car won't start.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3611471
So the factory alarm is supposed to be stripped as part of compliance? If so, what is the little fob thing on the key chain for, and also the sensor looking things on the dash? Do they do anything?
who did the compliance on it? if ISASO then it was me that removed it. I've had 3 of them disable 3 cars on me so when I do the compliance immobiliser them they come out. its not factory anyway. they are dealer fitted and some of them are barely fitted. most are in with scotch locks and they are ALWAYS loose.
the black tag on your keyring(autowatch badged) is the Immobilser. two pt std issue. the round thing below the boot release switch that looks like something pushes into it does nothing.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3612926
hey guys,
just a quick note about the adr82/00.. if the vehicle is fitted with a factory immobiliser there is a way around having to replace it
dotars recognise the ULC-S338/98 which is the canadian standard for immobilisers (all vehicles in canada must be fitted with an immobiliser whether stock or aftermarket)..
The ULC-S338/98 does mention the Infiniti v35 so all you need to do is prove to dotars that the v35 and g35 have the same immobiliser (which you can grab of the Nissan Fast system)
We have been using this evidence for most vics and dotars have never questioned it...
hope this helps
cheers,
k
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3613715
I'll apologise in advance for my lack of knowledge both in this area, and cars in general. So I have the keychain thing, the two sensors on the dash, a small light just under the clock that flashes once the keys out of the ignition, and a red light labelled "Security" to the right of the steering wheel. Do I have an immobilisor or an alarm, and if so, how can they be activated?
Also, I got the car from a dealer in Sydney who do their own compliance.
Sorry again, this isn't really my thing! If I was in Brisbane, I'd be over seeing Chris Rogers already!
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3615516
word of advice- leave it all alone. if you activate it by mistake (IF it works- see other post ) then you have stranded yourself. if you have the nissan branded tag press it into the slot below the steering column. that will activate the dealer fitted alarm. the OE one 1s self triggered. the autowatch one is the same.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3615654
  • 4 years later...
any of the alberts stores. see cannington and speak to pete. get them to toss a autowatch 446 P in it.
Hi Chris,anyone you could recommend in Melbourne?
Edited by rawzz_v35
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-6401388
ok so stopped down at Alberts today. They are going to put in a slightly different system that runs off my car key. $550 installed.
Sound about right? I asked for the Autowatch 446 Premium, but Pete was talking something slightly different.
Once its booked in, I'll let you know exactly what it is :)
Thanks again!
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-6405179
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
