Better off with N/A than getting a "master power" turbo.
if its cheap, its cheap for a reason :blink:
Actually don't know anyone who has had a problem with one yet.... couple of high profile cars in NZ have been running them hard fine. Don't know much about that particular unit however.
https://www.sau.com.au/forums/topic/176572-turbo-specs/#findComment-3229946
T series wheels are dinosaurs as are T4 turbines . If you want to stay with a bush bearing Garrett based turbocharger I think you are better off looking into Garretts GT bush bearing turbos . Quite a bit cheaper that their GT ball bearing turbos and better overall than
the old T3 and T4 based turbos/centre sections . They are based on the GT32/35/37/40 etc turbines .
Cheers A .
BTW what sort of power are you after on what engine ?
Edited by discopotato03
https://www.sau.com.au/forums/topic/176572-turbo-specs/#findComment-3229985
Cheers A .
my power goal is around about 260-280rwkws i already have a cast iron T4 flange HKS manifold with a HKS 50mm waste gate.
https://www.sau.com.au/forums/topic/176572-turbo-specs/#findComment-3230677
if its cheap, its cheap for a reason :)
do you think Master Power turbos are cheap or something?
Master Power was founded in 1966 by Nelson Borghetti. Old skool rally cars used their turbos, they are NOt your average chinese copy made in taiwan crap cast turbos.
You are mis informed R31nismoid
https://www.sau.com.au/forums/topic/176572-turbo-specs/#findComment-3230745
If your HKS manifold is the one for the RB20/25DET then yes it has the T4 flange BUT the outlet ports and stud holes are split T3 pattern . If it were me I'd look at a divided housing GT3271 or possibly a GT3576 if I could find a suitable A/R housing for the 3576 . I think the 50mm gate will be too big and was under the impression that manifold used the HKS 40mm external gate ?
Will get back later about other twin scroll turbo options because there may be a few useful things in the TA34 range .
Cheers A .
https://www.sau.com.au/forums/topic/176572-turbo-specs/#findComment-3230934
Cheers A .
cool sounds good thanks
https://www.sau.com.au/forums/topic/176572-turbo-specs/#findComment-3231046
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
