/hijack
mine is playing up as well, it will only lock with the key and is sometimes hard to get to lock even with the key. this started soon after me slamming the door really hard... (women)
any ideas on how to fix?
Had this same problem a few weeks back, turned out the "gears" in the locking mechanism were full of gunk inside the door. I cleaned it up, made sure it was well lubricated with some oil and then put it all back together. Haven't had a problem since, hope it helps :blink:
either that, or check inside where the lock is in the actual car frame, see if its still connected;
when i had my alarm installed, the passenger side would lock. this was due to the locking bit where the clip on the door inserts into to lock the car.. in mine, it was disconnected/broken.. fixed it up with duct tape :blink: before i can get a new one(like 5 bucks if that off a wrecker)
mine was doing the same thing...thought it was a dead actuator so i gave the spare i had to my installer...he gave it back to me when i picked the car up and said it was a crushed wire that came from the car into the door...ran a new wire and all fixed :blink:
  • 3 weeks later...
same problem, only on the passengers side, and the door is locked and won't unlock, it appears something in the solenoid is jammed and is preventing the actual door opening mechanism from working >_< f**k it's pissing me off, i've been playing with it all morning, can't get the sucker to open.. any tips?
i had Doug from Eastside Installs come around yesterday to have a quick look at my alarm as i said above, i have the same problem...
it was easy to fix, just a wire in the door that had gone bust, split by the door... easy fix... :D hope this helps?
great success! i didn't take any photo's but if you've ever had the lock mechanism out before it's not hard to picture..
there are 2 screws that hold the solenoid onto the lock mechanism, and another screw that was missing (presumably come undone and fallen out some time ago) that held the solenoid to the frame of the door.
over time it appears that the plastic bit of the solenoid that pivots the door lock up and down had been flexing against itself and somehow eventually come out of the door lock mechanism..
effectivly this jammed the door lock from unlocking, the only way i found to overcome it was to use a long flathead screw driver with a thin blade to wedge inbetween where the two attach each other and then rotate centrifigully, flexxing the solenoid away from lock mechanism and allowing the door to unlock :huh:
works a charm once you sit down and take your time figuring out how it all works, which is pretty hard when the fken door won't open and the only way you can get inside the door is to flex the interior trim :S
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
