thrtytwo Posted July 16, 2007 Share Posted July 16, 2007 just crossed my mind when i was reading something, i dont know if my car has ever had a long term service, when i got it i think it had about 127kms on the clock. everyone tells me it runs well and there are no issues ? can i check to see if theres a timing belt sticker or something ?? cheers Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/ Share on other sites More sharing options...
gazza750 Posted July 16, 2007 Share Posted July 16, 2007 if they have replaced the timing belt there is usually a sticker on ya radiator shroud saying @ what k's it was replaced well thats where my sticker was Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3232441 Share on other sites More sharing options...
thrtytwo Posted July 16, 2007 Author Share Posted July 16, 2007 cheers ill check it out, if i see nothing will get c-red to have a look Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3232723 Share on other sites More sharing options...
GODTHRILA Posted July 17, 2007 Share Posted July 17, 2007 cheers ill check it out, if i see nothing will get c-red to have a look Just had mine done on Friday... i guess take the timing cover off and look to see if the belt is factory or aftermarket... if its factory then its either original one, or they replaced it with a factory item... so then look to see if anything else there looks newish. I have a new water pump and 1x tensioner pully so thats how you'd spot mine. Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3233175 Share on other sites More sharing options...
NISZILA Posted July 17, 2007 Share Posted July 17, 2007 I thought they put the sticker in the cam cover. Thats where mine is. Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3233410 Share on other sites More sharing options...
thrtytwo Posted July 17, 2007 Author Share Posted July 17, 2007 I thought they put the sticker in the cam cover. Thats where mine is. they can probably put it anywhere in the general area, will depend from shop to shop most likely Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3234126 Share on other sites More sharing options...
infamous_t Posted July 17, 2007 Share Posted July 17, 2007 If you can't find any evidence, or are unsure, get it done anyway... get your other belts replaced while your there, they most likely need it. Works out cheaper than a dead engine. While there, get your radiator flushed, water pump checked/replaced etc, as labour wise it can all be done at the same time, your just looking at extra parts cost. Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3234205 Share on other sites More sharing options...
ossie_21 Posted July 17, 2007 Share Posted July 17, 2007 The sticker is in Japanese & it says something along the lines of replacing it at 100,000km, and there should be a couple of spaces. If it was done those spaces should be filled out with the date it was replaced & I *think* also the km on the clock... Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3234395 Share on other sites More sharing options...
thrtytwo Posted July 17, 2007 Author Share Posted July 17, 2007 yeh had a look and i can see where the sticker would of beem on cam cover but its gone haha, slight outline of where it was though, also my belts look new, brand is pitwork not nissan aswell. the waterpump looks relatively clean and has red sealent overflowing a little at the edges, guessing it wouldnt look like that from factory ? Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3234662 Share on other sites More sharing options...
turboedsloth Posted July 17, 2007 Share Posted July 17, 2007 na someones been in there. nissan sealant from the factory is usually grey. toyota is red generally Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3234692 Share on other sites More sharing options...
thrtytwo Posted July 17, 2007 Author Share Posted July 17, 2007 na someones been in there. nissan sealant from the factory is usually grey. toyota is red generally thnx for the info makes me a happy camper, now i can spend my money elsewhere http://www.skylinesaustralia.com/forums/in...howtopic=176926 Link to comment https://www.sau.com.au/forums/topic/176801-100000km-service/#findComment-3235116 Share on other sites More sharing options...
