Does anyone know which company sells the adaptor plates so you can run an rb26 plenum and multi-throttle setup on your rb25? I know the Blitz D1 car uses one but i cant seem to find any info on them selling them either. Just trying to find a cheaper/better alternative to the greddy plenum.
cheers,
Jarrad
https://www.sau.com.au/forums/topic/176856-rb25-6-throttle-adaptor-plates/
by the time you do the conversion it cost about double a greddy plenum but it does offer superior throttle response and an average 40hp increase by itself...... i have done 1 and sold 3.
i have the last adpator plate blitz made stashed for a rainy day. I can if there is enough interest get them made again (japan) but only in lots of 5.
If your after info speak to ADZ or Ben at race pace he fitted one i supplied to ADZ's animal R32. This car is a real credit to Roshan, Ben, meridian and Adam
or just buy the one off yahoo that another company makes for $520
but as Trent said its not a cheaper option
have you got that link? ive seen a few sites that show them ie rb30.com but the original company wants orders in multiples of 5..... which sucks. i got two Middle Eastern customers chasing them and i would love to be able to hand ball it with a link :)
$520 sounds about right. The rb30.com doesnt come with the metal gaskets so factor in another 100-odd and it doesnt come with any of the remote billet vacuum bosses for IAC etc which would cost about another 200. So far $800-odd and you havent sourced the gtr plenum and ITB's... food for thought.
Stay Tuned here.
I'm working on an adapter for this exact application.
Will be waterjet cut including tapering of the airflow section to match both the head and the manifold.
Will be CNC machined and made properly.
Stay Tuned here.
hope you include all the other billet adapters for the IAC and so forththat the current jap manufactures are no longer doing... as the kit is fairly useless without them.
cheers,
Jarrad
hey jarrad,
if i remember right i was quote $600 for the complete blitz kit, as it doesnt just come with the adopter plate, its got a few other bits!
if u can get a gtr plenum for $300 and maybe get a set of 550cc injectors for a gtr for around $600 i think its well worth it. ive been meaning to do this for years BUT im just tooo lazy AHHAHA!
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
