  • Replies 41
Posted Images
nah, it's just more convenient. no passengers allowed on track anyway, plus with passenger seat out my race box fits neatly in the space. i just put it in after track use. takes about 3 mins tops.
ahh cool nice...
Thanks Richard!
I'll return the supercheap one on the weekend or thursday!
Guys: Postage on that firstaids side is "'$16.50" for 1 and when I put in quantity as 2 it's the same :(
Maybe I could email them and ask for a group buy?
any 1kg extinguisher is not up to the task if ur car is on fire its only design to reduce the initial fire before assistance arrives. if ur driving till the point of overheating/fire (this is why u look at your gauges) or havent done the checks before a tack day is more important than anything else. as far as i know many guys dont even have heatshield's on their manifold/turbo/dump etc etc when those are the biggest fire hazard.
its the same chemical compressed to the required pressure and 1 valve. all the same shit if u ask me.
yes spend the extra $20 for peace of mind i can understand, but when it comes from supercheap, they wouldnt be allowed to sell it if IT didnt met standards.
dont be too quick to based price on quality.
where are the bfi ones made anyways?
Edited by philta
there are big differences between so called 1kg extinguishers. some contain only around 500gm of chemical, some contain over double that. they are all rated though.
what's the rating on the supercheap one?
is that one of the foam bomb type extinguishers used in open wheelers? and looks externally activated (or atleast one trigger near the dash)
Yer craved thats correct is a 4kg unit with 6 spray nossles and 2 pull cables one for me in the driverseat and one on the right hand side front wing
they are an awesome setup, havent seen them used much in sedans though. worth it for sure
We have to run to FIA requirements and this is the requirement :-) 3 sprays inside and 3 under the hood. was only about 330$ so not to bad
Richard do you trust those those two small bolts in the bracket to hold the extinguisher back from flying off and getting you in the legs when you have a high speed off/stop?
Not sure what force is generated by a lkg+ mass when you do a Radisich Bathurst 06 into the wall but it's a lot.
They may be more than enough but just thought I'd put the question.
Cheers
Cheers
yeah they should be fine. it's not on the drivers side of the car and i have been backwards into the wall before and it didn't budge. for sure they are not massive, but the extinguisher is very light, 2kg total weight. granted I wouldn't want it flying at my head though. not much option to fit any bigger ones sadly. :D
    • I'll give it a go, it cannot hurt Although, every time I go to Bunnings for one thing, I end up with a trolley load of stuff In other stuff news, I can fit 6 x 15kg bags of Gypsum in the boot of the MX5, I could have put a few more in, but I was already pushing my comfort levels buy dropping 90kg into to boot....LOL
    • It seems to happen only when moving not stationary. It happens more frequently when reversing and turning steering wheel to the right. I MAY have found what the sound is and if it’s that I will feel so dumb since it did start happening around when I put 18” wheels. I attached the image of where there’s a scraping line to that plastic liner and the other side does not have that.
    • Is it a noise that if you turn the wheel, and hold it turned to the right, the screech continues? Or does it only occur while you're moving the steering wheel? Does it occur when stationary turning the steering wheel from centre to the right?
    • I want to also note I did lift the tire and checked for any play to see if it was a bad tie rod. It doesn't move at all.
    • Any insight will help find the issue. When I do a sharp turn to the right I hear a screeching sound coming from the front. It only happens turning Right and not Left. Steering fluid seems okay. Not sure what this part is(picture) but one side seemed "wetter" than the other. All bushing from a quick look did not seem damaged. I'll do a better look but wanted to ask here in case it helps me troubleshoot faster.
