  • Replies 41
Posted Images
nah, it's just more convenient. no passengers allowed on track anyway, plus with passenger seat out my race box fits neatly in the space. i just put it in after track use. takes about 3 mins tops.
ahh cool nice...
Thanks Richard!
I'll return the supercheap one on the weekend or thursday!
Guys: Postage on that firstaids side is "'$16.50" for 1 and when I put in quantity as 2 it's the same :(
Maybe I could email them and ask for a group buy?
any 1kg extinguisher is not up to the task if ur car is on fire its only design to reduce the initial fire before assistance arrives. if ur driving till the point of overheating/fire (this is why u look at your gauges) or havent done the checks before a tack day is more important than anything else. as far as i know many guys dont even have heatshield's on their manifold/turbo/dump etc etc when those are the biggest fire hazard.
its the same chemical compressed to the required pressure and 1 valve. all the same shit if u ask me.
yes spend the extra $20 for peace of mind i can understand, but when it comes from supercheap, they wouldnt be allowed to sell it if IT didnt met standards.
dont be too quick to based price on quality.
where are the bfi ones made anyways?
Edited by philta
there are big differences between so called 1kg extinguishers. some contain only around 500gm of chemical, some contain over double that. they are all rated though.
what's the rating on the supercheap one?
is that one of the foam bomb type extinguishers used in open wheelers? and looks externally activated (or atleast one trigger near the dash)
Yer craved thats correct is a 4kg unit with 6 spray nossles and 2 pull cables one for me in the driverseat and one on the right hand side front wing
they are an awesome setup, havent seen them used much in sedans though. worth it for sure
We have to run to FIA requirements and this is the requirement :-) 3 sprays inside and 3 under the hood. was only about 330$ so not to bad
Richard do you trust those those two small bolts in the bracket to hold the extinguisher back from flying off and getting you in the legs when you have a high speed off/stop?
Not sure what force is generated by a lkg+ mass when you do a Radisich Bathurst 06 into the wall but it's a lot.
They may be more than enough but just thought I'd put the question.
Cheers
Cheers
yeah they should be fine. it's not on the drivers side of the car and i have been backwards into the wall before and it didn't budge. for sure they are not massive, but the extinguisher is very light, 2kg total weight. granted I wouldn't want it flying at my head though. not much option to fit any bigger ones sadly. :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
