'95 S1.5 r33 gts-t with 126,000kms. Haven't had any troubles with it apart from a dudd battery. I'll be selling it in a year or two and getting a supra anyway so the mileage doesn't bother me. Way I see it, a higher odometer is probably closer to the truth than a lower one. They are getting pretty old now aswell so I'd be surprised if most weren't around the 100 mark.
https://www.sau.com.au/forums/topic/176953-kilometers/#findComment-3235099
1995 R33 Gts-t - bought with 90 000km 4 years ago and now its done 210 000km. Only problems I have had with it are the usual wear and tear type things - but I am sure things will start falling apart soon.
I guess it goes to show that if you look after it with regular maintenance etc they can go for many years!
Series2 33 GTST. Bought May 06 @ 63000km. Now has 93000 on it running higher boost etc... No problems as yet.
https://www.sau.com.au/forums/topic/176953-kilometers/#findComment-3235450
Now here's a car with nice low genuine kilometres
http://page5.auctions.yahoo.co.jp/jp/auction/e63812200
I love google translation tools!
Relationship of the system of course the condition of interior and the wrapping is good very, also travelling actual travelling 58000KM the male is completed is your degree preeminent car very little without either the sash and the colour fade-out etc of the body surface.
Of course there is no restoration calendar! You can say that it is the genuine best car 輌 by the actual travelling car.
Furthermore because the additional photograph is attached finely, when reference it receives please and question and the like is communication we wait to description below without modesty.
Furthermore, please request preliminary inspection and test drive etc without propriety modesty.
https://www.sau.com.au/forums/topic/176953-kilometers/#findComment-3235556
rofl @ the google translation!
'90 R32 GTSt purchased privately in Sept '06 with a supposed 99,***km (yeah right), now at about 115,***km.
Hasn't missed a beat, had to replace the front left stub axle when I got it as the previous owner put it over a kerb and had a few dramas with the breathing setup which the last owner fubar'd, ran 14psi through the RB20 turbo for 6months then put the RB25 turbo on. Only other minor drama I had was an exhaust leak from between the turbo/manifold. Had it dyno'd on the weekend and it made 195rwhp @ 5300rpm and about 12psi but they shut it down early as it was running a bit lean.. time to get that 044 in! ;)
https://www.sau.com.au/forums/topic/176953-kilometers/#findComment-3235583
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
