The other day when coming out of my work carpark, my car (r32, rb20det) lost all compression and moved like a slug.
I dropped it off at my mechanic who has just informed me that it has extremely low compression and a rattling noise in the engine. This means that it isn't combusting fuel properly and well...just not going.
I think that I have two options now:
1. Strip down the engine and find out what's going on
2. Replace the engine
Would anyone have any suggestions in what could have happened? Or any other options I might have?
Thanks.
Option 1: Would mean labour costs plus rebuild if your intending to keep the RB20 and add forgies
Option 2: Replace it with a second hand RB25DET or another RB20 if your tight on funds, make sure you get a leak down and compression test on them before purchase.
i'll personally prefer a cheap RB25 and wack it in there.,
Were you giving it stick at the time of coming out the car park? Generally speaking motors just dont die and lose compression like that unless they have detonated (cracked ring lands, bottom end bearing and various other things could be damaged) or your oil pump has died causing bearings to run dry and spin.
If the motor is stuffed, i'd look into replacing it with an Rb25 (minus the box) and take it from there, you can get them for around 2200 with ecu and loom + all bolt ons.
I like GT shortie's second option.
Rb20s are cheap as chips (<1k). Rb25, more.
If I were to blow my engine, that's the option i'd be taking. Sure, building an engine will make a stronger engine, but they cost a lot. The stock one will take a good whack of power if you look after it.
i'll look into swapping to another rb20. i've already got all the supporting systems for it and it'll probably be an easier swap without having to worry as much about wiring etc.
are compression and leakdown tests able to be conducted on an engine not in a car?
by all means put in a second hand RB20, BUT make sure you figure out why the first one went bang so you don't do it to the new one (ie, dud fuel pump? bad tune? broken injectors?...)
well, everything was given the twice over and it came back to the engine itself. the fuel pump, injectors and tune were apparantely retested and still running a stoich mixture but the engine is just losing compression somewhere. there is also a worrying rattle inside the engine somewhere which sounds like a loose bearing.
For the price of a 25..
you can get a 20.. and some nice mods..
Better off spending money on a 20 and mods..
see if you can repair the 20 and sell to make a little bit of money for more mods..
well it shouldn't be running a stoichiometric AFR anywhere except at cruise (light throttle, low load) if it's running stoich anywhere else then you have big problems.
anyway, I would do your best to pin point exactly what killed the motor as it wont be much funning fitting a new one then going through it all again.
it's running stoich at low load and off boost and a tad rich on boost. not sure of the exact afr's tho.
would it be worth paying for the motor to be stripped down to find out what's wrong before going further?
If they just tested ur fuel pump by adding power and not running in a motor it doesnt mean too much.. Could have been leaning out under boost and running to lean for a while. GTS4WD U could get another with some mods, to catch up to a 25 and then some. Or u could just get the 25 and the base right there for some really good potential. All comes down to how much cash u wanna spend. Spend ur cash now on a 25 and get better results later with mods or spend the same amount on a 20 with mods and have more power than a stock 25 with lower gains for all the mods u do in the future.
Liam
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
