So I want to replace both my front and rear windscreen seals, since they look worn out from sun exposure with little cracks here and there.
Any idea where i can obtain new ones of these seals? Nissan Japan?
By the way, I'm talking about that black rubbery thing around the windscreen.. matter of fact, i want to get the whole thing replaced both rear+front & two sides.
https://www.sau.com.au/forums/topic/177197-windscreen-seals/
My god, that's outrageous..
So all up, it could cost me close to 1k just for front and rears.
Would i need to buy the molding kit, is it really necessary?
How do i order these seals? Just go to any Nissan parts dealer in here? Or do i need some one, perhaps a parts importer who can contact Nissan in Japan and get some down here for me?
On a cruise i met a guy with r32 gtr who got a mobile windscreens obrien guy to install a rear windscreen. The bloke used a generic seal that fitted well and looked good. It was a bit wider than the stock one but looked a hell of a lot better than my old ratty peeling back seal. Cant remember price for seal, was less than $100.
not 100% sure on QLD but here in sydney you can buy them from any nissan parts department. and yes, it's expensive!
OEM for looks.
Generic for the Wallet.
My back window is a generic seal (damn petrified birds) most ppl don't notice, and looks fine...
but if your picky which your seem to be (are they $1K+ bad?)... then its the wallet option.
+4 on the universal seals
They look better in my opinion, the standard nissan ones seem to fall off or peel back at high speed
I lost part of my rear one, and then found it under my wheel :P scratched to pieces, i'm going 1 piece generic, it'll just look much cleaner than the 7 piece top seals the R32s have :S
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
