Hey guys, im getting some stuff done to the car.
Skyline R33 GTS-T
I've already got a pod filter on the car. Everything else is bascially stock.
Getting a dump pipe, intercooler, EMS ecu, boost controller.
EDIT - Its going to be running 13psi :D
Its going to be tuned, how much rwkw do you think i'll be getting, just a ruff idea so i know what to kind of expect, so that i know if the tune is good or not.
Thanks guys.
Edited by Crash.
https://www.sau.com.au/forums/topic/177201-how-much-rwkw-do-you-think/
Skyline R33 GTS-T
Thanks guys.
You will be looking at 180-200, depending how happy the dyno is.
You going to keep stock cat and cat back?
You will know if your car is tuned good by how it runs and its A/F ratios, not necessarily the power it makes.
Edited by bluey33
agreed....u replacing the rest of the stock exhaust....important that you do...
all depends on the car...
mine was completely stock and made 144.5rwkw. I did the full exhaust, fmic, pod, 12psi and made a little over 200rwkw...
others have done the same and made 180rwkw....
but exhaust is important
i have run a 13.426 at 103mph on nittos....granted it was a freakish time and the closest i have run to that was 13.578 but it can be done....
just had turbo back exhaust....plenty can vouch for me
DON'T LIE!!!!
I'm kidding...
but Nittos...
I don't consider it a true indication of a time someone can run with regular street tyres.
what was your 60' time?
less than 2.0 I'd assume?
most people will be lucky to get that sort of launch on their regular street tyres that they drove there with..
only if u have full turbo back exhaust.....
also just to let u know that alot of ppl think that stock turbo should be max 12psi....i have it at 13 only at the drags at night and its below 12 degrees...
dont want a bang.....
170-180rwkw tops (legit).
Mainly because your only have a dump pipe, the rest of the exhaust will still pose a signifigant restriction, based on the point you said everything else was stock.
Restriction is the enemy of a turbo. Clear that up and a result closer to 200rwkw should be the result
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
