Hi All,
Regretfully selling my Baby ...
Before buying the car and before doing the modifications I took every care in ensuring that what I was buying was of a top standard. Take this opportunity to own a gem that's been babied since being imported. This included getting an Engineer's Certificate as well having CRD perform Compression and Road Tests prior to purchase. Contact me if you have any queries whatsoever. Will be up on Carsales tomorrow.
Notes
· Bought last November, selling due to returning to studies / moving out of home
· Rego Til November
· Engine in good condition, compression and leakage tests were performed on the car by Croydon Racing Developments.. All A1 (documentation available)
· Genuine weekend car. Meticulously Taken Care of (and loved) serviced every 5000kms with Motul Turbolight oil since being imported
· Grade 4 import, all import documents will come with the car
· Comes with Engineering Certificate for non standard modifications!! (excludes POD Air Filter)
· 200rwkw (have dyno sheet)
· Serviced 3000kms ago
Details
·    Nissan Skyline R34 GTT
·    59XXX kms on the clock
·    2 door Coupe
·    Turbo
·    5 Speed Manual
·    XENON Headlights
·    Traction Control
·    HICAS 4 Wheel Steer
·    Power Windows
·    Power Mirrors
·    Air Conditioning
·    Climate Control
·    Dual Airbags
·    GT Wing
·    Keyless Entry
Performance
·    17" AVS Model 7 Rims (With Good Rubber)
·    5Zigen Cat-back Exhaust
·    Blitz Boost Controller
·    FET Turbo Timer
·    Front Mount Intercooler (Croydon Racing) – Near New
·    Monza Racing Pedals
·    K&N Pod Aircleaner – Near New
·    Go-Fast-Bitz Plumb Back Blow of Valve – Near New
·    Professionally Lowered approx 1.5†in Japan
Sound / Security
·    JVC Double Din DVD/CD/MP3 Head Unit
·    Kenwood Splits
·    Powerful Amplifier
·    10†Sony Xplod Subwoofer
·    Upgraded Car Alarm as professionally installed by LifeStyle Store Parramatta
Contact:
Ron 0415556722
[email protected]
See attachments for Photos / Will take more pics this weekend.
$24k ono WITH STEREO, $23k ono without
Thanks
Edited by derek zoolander
Car will come with Stock Airbox (no snorkel), Stock Side-Mount Intercooler ...
Will also consider any trades + Cash Adjustment. Looking for something around the 5-10k mark, something cheap but fun to run around. Preferably non-turbo, manual.
Cheers guys.
Been asked this quite a bit, but I am fairly negotiable on price guys.
Remember the car comes with an engineers certificate for most of the mods plus a very good sound system, so there's no more to spend.
Cheers :)
Hey guys, i have listed everything that I know of.
I was actually quite (happily) surprised too when CRD handed me the Dyno Sheet.
Cheers
Ron
  • 4 weeks later...
okay - haven't looked at this in a while due to being way on business. looking now for quick sale ...
$24k ono with everything
$23k ono without DVD player & amplifier
I am going to sell my Audi A4 1.8T and get a R34 GT-T. I was planning to advertise my car for sale next month when I have more free time.
But, just see if you are interest to swap with an Audi first?
I had a R33 GTS-T about 3-4 years ago and I would like to get a R32/33 GTR or R34 GT-T now. Please let me know and I can provide you more details with my car. Thanks!
Edited by Nismo_R33
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
