V35 Modifications
Has anyone looked at supercharging their 35s? Vortech make a pretty cool bolt on kit to get you about 400HP at the engine - and its only $6k landed from the USA. Could be a bit of fun :yes: I believe it comes with timing and fuel computers or something. Perhaps we could do a group buy down to Aus?
JK
  • Replies 49
I considered a turbo kit but my V35 is auto, so i thought a supercharger would be nice and fluent with the power delivery. Plus i have no intention on rebuilding the engine so about 8psi on a blower would do me fine?
JK
I have a HKS S/C kit on my car and I love it.
Nice and quiet (unlike the Vortec)
It only boosts 5 psi which is plenty if you want the engine to survive long term.
Gives more power everywhere.
Only 300hp to the the wheels which is enough for now.
Pre tune (about 270hp) ran the 1/4 at 13.7 with traction issues
Chris, You still owe me a drive with the new SC, then we can decide whether to put one on the Z :thumbsup:
Anytime mate
Be careful though you'll want one instead of the Zed :rofl:S
Whereabouts did you get your kit from? And did you fit it yourself? What ECU do you run, and who tuned it?
/101 Questions
JK
My kit came off a 350Z
Yes fitted myself
The kit comes with a F-Con pro piggyback computer and was tuned by XSpeed here in Perth
Not that I'm in a position to get one, but I found a while ago that the Greddy twin turbo kit was pretty much the best value of the lot.
Unless they've fixed it, the GReddy kit isn't a complete kit. I forget what parts you need to get on top, but when you spec it out it ends up being almost the same price as the APS. And I've read mixed reviews about it.
I've driven a 350Z that had the HKS supercharger, and then the HKS single turbo kit, and the turbo is far superior. While they both made the same peak power the ST feels a lot stronger, and is easier to crank up the power on.
I'm not a big fan of centrifugal superchargers, either.
When I run my 1:09 at Wakefield in street-legal NA tune, I'll probably investigate the HKS ST.
Far superior?
I beg to differ
My V35 Supercharged versus a 350Z HKS ST on same dyno
Agreed easier to turn the wick up on the ST but at the risk of engine problems
Just got my V yesterday and I reckon its got some bloody good poke in auto natro form. I really cant wait to charge it!. I definately think the Vortech kit looks the go but Im not sure what u need ECU wise for it. The HKS kits always impress me so i may lean that way. Any hidden surprises with yours mr R34?
Cheers
Jai
Cheers
Jai
No but plenty of surprises for LS2's and STI's :laughing-smiley-014:
The HKS is pure stealth which is the way I wanted it ...Vortec's are very noisey
Nige, is that a photo of your engine bay?
Nah they wont sell me one because the say my wife will kill them and she would, I get a new car every 6 to 12 months so I don't like pumping big dollar into my cars now,
I am not to far off 230 rwhp and a few more big mods to do as I would like 240 to 250 rwhp in NA as they drive quite well, I will run any one I would in my EVO 8.
 Share
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
