Morning all,
I've decided to kick the old hicas out of the car. I'm ordering a lock bar, should i take out the hicas gear aswell? does it weigh much?? and moving onto my main question. i've bought an Isotta steering wheel and need to buy the boss kit. i need a special boss kit to accomodate the hicas. as i'm getting rid of hicas do i still need that special boss kit??or will a standard one fit once gone. (i'm not quite sure of how the hicas one fits differently)
Cheers!
https://www.sau.com.au/forums/topic/177365-hicas-changing-steering-wheel/
all the hicas gear from front solanoids to rear and lines weighs i dunno bought 25kg at the most i guess? maybe 20kg?
i've removed mine + lines, keep the rear computer, beucase otherwise it'll make your steering heavy, you can use skyline non-hicas or 180sx boss kits once the hicas has gone :D i got mine for $110NZD including boss kit and wheel, nismo look a like and it's fine for now
if you have a GTS4 I would be getting the correct steering angle sensor compatible boss kit. as I believe the AWD needs steering angle input to operate correctly.
I didnt even think of that. cheers for the input guys. I'll stick with the proper one that is made for my model.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
