Hey all,
Got all the nuts off the head studs, the only thing i can see still holding the manifold to the block is the gasket, and the bitch won't move.. I've wedged a breaker bar between the head and the manifold and put a fair bit of pressure on it but it seems to no avail..
Has anybody got any hot tips on how to get this f**ker off, or what might still be holding it on?
cheers in advance,
Mark
https://www.sau.com.au/forums/topic/177392-exhaust-manifold-removal/
yeah mate pretty sure all the nuts are off, the gasket is sticking it together like all hell, i'm afraid to use too much pressure with the pry bar... i've never actually had to remove a manifold off an RB before, are there any hidden bolt locations that i could've missed like there is with the head? :S
the aluminium head is the reason i don't want to put too much pressure on it :laugh:
yup, just went and counted 10 nuts with no bolts on them, and 2 holes where there were no studs, obviously been taken out at some stage during the engines life and not replaced :S
have any other people had occurances where the gasket had caused the manifold to stick to the head?
Edited by aphid
It'll come off. I've had one a bit sticky before. It was because one of the studs was half snapped, and it was wedged against the edge of one of the holes (if that makes sense), since the manifold was warped.
Try tapping it lightly with a mallet. Lightly, not smash it like crazy
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
