  • Replies 843
Posted Images
Cant Remember if its been covered and cbf reading through 8 pages.
Pump Fuel or Race fuel? and will it still be gassed up.
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :P
Regards Andrew
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :rofl:
Regards Andrew
In order:
- Race fuel
- Yes
- Didn't sell the box from this car. I still have the C6 in it.
Intake update: I can get a couple more of these (plenum/TB) at $1400 if anyone is keen for one. Just send me a PM and I'll sort it out. They use the std throttle cable and TPS as well.
Adrian
Looking very nice man - how quick are you aiming to go with this???? Going by your nack, I'm not going to be surprised if I hear very near single digit numbers - if not...
Thanks mate. I don't know if this setup will have a 9-sec pass in it to be honest but it'd be nice to do. Not sure if the GT35 has it in it but there's only one way to find out :thumbsup:
Hello Mrs Courier!
These look bloody awesome. The throttle body is a work of art too - can't wait to bolt it up and have some fun!
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :thumbsup: )
Good luck,
Ryan
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :banana: )
Good luck,
Ryan
Thanks for the tip. What did you make it from?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
