the plenums are very well made, just need a little refining.
i like to retain the metal gasket with the rubber orings. this gasket only came out in series 1s, and you cant get them any more. they hold their shape and seal well. the all rubber gasket moves and gets squeazed out the side. have removed these seals when the metal one was not available and just used a paper gasket with sealer also. this works, but have to discard the studs supplied also.
Too bad about the Plazmaman plenum Stuart, I made a thicker gasket for my plenum (I think it mentioned that in the instructions that came with it?)
Looks like the build is going on very nicely though.
Keep up the good work and look fwd to see how it goes on the black stuff. :laugh:
  • Replies 843
Posted Images
I picked up the correct throttle body from Plazmaman last night after Compak Attak and saw that their new plenums have a revised throttle mounting setup that allows enough room for the retaining nuts on either side. They also allow room for the fitting at the back that runs to the brake booster.
if you had of put both his balls in your mouth at the same time he might have given you the better one.......
A bit unprofesional to sell the plenum knowing that there was issues with it, unless it was cheeeeeeep.
Nevertheless, plenum is sorted, sump is also well underway so our work will be done very soon......hope to be finished this week.
sorry, i have broken the one beer rule again..
Edited by BezerkR32
engine assy is in and bolted up. Nothing major to modify, just have to relocate a few minor things, and mount some of the new additions but otherwise all good. Aftermarket balancer is incorrect however and will need to be replaced.
Shoud complete the majority of these things today with exception to the balancer. Thermo fan & shroud will also require fitting as engine fan and factory shtoud no-longer fit.
If more people knew the grief involved before they started there would by way less modified cars out there. Its been almost 12 months of modifing the modifications, hacking, cutting changing, discarding, reaarranging components to get it all to work as a unit. I thought I did my homework but there are so many hidden perils just waiting to bite you on the arse.
The next person that tries to sell me a part and insists it simply "bolts straight on" will have said part rammed up their coit.
THERE IS NO SUCH THING AS A BOLT ON MOD?
Good luck with this build 2rismo and i hope your pain is way less than mine has been. There are quite a few up here keen to see your car run at jambo.
Every single part (or most) on our car has been Jap off the shelf stuff...why?...not because im rich...its because it fits and works everytime.
To Alex's defence...he once sold me a plenum that wasn't right...so the next day drove 6 hrs (3 hrs each way) to fix it.
Because it's an RB26.
The backup from the guys at Plazmaman has been great and they've been proactive about quizzing me on what should be improved.
the driveability of the 30/40 is excellent, have fitted this turbo to half a dozen r33s, two auto, the majority of these with standard internalls. adrians with the bigger exhaust housing due to the engine mods and use of gas. you be silly to upgrade to anything smaller. I would seriously consider gt42 if it is a auto race car.
Man my turbo is going to look tiny as a highmount compared to that.Maybe a GT3082 is on the cards :P
all-so finished the pressure side of the oil system, ran hose around radiator and through inline filter on driver-side chassis rail. there is a good 2 meters of -12 hose which eliminates the need for an oil cooler. mounted filter in a bosch fuel pump bracket.
my work is almost done.
Edited by BezerkR32
I opted for the GT3076 .82 as the car will be used mostly for club sprints and motokhana type stuff. Anything bigger and lag would be so annoying in the really tight and twisty sections.
Good to see that motor in though, im dying to get mine in and running.
definately the right choice for your application...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
