  • Replies 843
Posted Images
This is how a bunch of people suggested I mount the injectors:
First problem is having spacers machined up was a pain in the arse, second was how far out the injector sat from the hole in the runner and third was having the injector seal and seat properly. I grabbed a set of pre-fab bushes that use an o-ring around the outside to seat in the standard intake but even the biggest 14mm o-ring was too small to seal in them.
This meant I had to drill out the standard runners to suit the larger body of the new injectors. It has a slight taper on it now and because the injector sits further down in the runner, it now also uses the factory rubber bush from the side feeds for some extra support/sealing.
This is what it looks like now.
While the intake was off, I removed the barbed water fitting at the back (I hate push-on with a passion) and welded on a -6AN fitting for the water feed to the turbo. You can see it at the very back of this photo next to the back of the left rocker cover.
Also mounted the thermo fans correctly and modified the fuel filler door signage... lol.
Tuning it this Thursday.
nice work brother, fits nicely, and doesnt leak, well the front half of the car anyway.
who was the brainchild behind mounting the injectors like that? he must be very clever...............you would think he had done it before lol, with less hassle though. maybe he should get a job designing top feed injector kits for rb25......oh wait they already are available. whats that, they dont fit........you have to remove the intake runners and modify the seats, no-way.
now lets boost this eco-friendly monster.
Let's see, it's the Nissan loom with different injector clips on it...
Swapped my old e-Boost2 for a new one yesterday. Thanks Turbosmart!
The new version has sexy new features (that I won't be using) but the design is much better than my old one. The vacuum line isn't fixed into the back of the head unit and the electrical plugs are flush mounted to the backing instead of sticking out. There's also no more silver bolt poking through the back.
Don't get me wrong - 335kw is a good level of power, but I would have thought even on a low reading DD and through an auto - 335kw would be a bit low for a built/cammed RB25 on E85 running 22psi and revving to >8000rpm? And mid 5000rpm for full boost, even with a 1.06a/r hotside? That, and the fact the power goes flat makes me wonder if something weird is going on - trans slipping, or an air leak?
Either way its clearly got the goods to go fast, but I really was kinda expecting more power than that.
Feel to set me right if I am missing something. Was there any reason you didn't go for a more aggressive boost level?
The power going flat is a function of the big converter. It's not really going flat as much as the left side of the graph is artificially full because of the flaring converter. Air leak? You think we wouldn't have found that? Come on man. :)
I mentioned that I need more spring in the gate already (only has a 7psi spring right now) and that I can only see 21psi no matter the duty on the EBC and I made a guess at what it will do when I wind it up. No Sherlock Holmes'ing required dude.
The power going flat is a function of the big converter. It's not really going flat as much as the left side of the graph is artificially full because of the flaring converter. Air leak? You think we wouldn't have found that? Come on man. :down:
Haha don't worry, I figured there was more to the story than I picked up on - but you gotta know to understand :P The converter thing makes a lot of sense, I've not really been exposed to them before but have seen quite a few dyno plots from auto cars which look like that... hadn't really thought too hard about it so cheers for the explain.
Sounds good, and sounds like there is more party to be had which makes me happy - looking forward to hearing what she does when you hit the strip with the latest setup!
Haha don't worry, I figured there was more to the story than I picked up on - but you gotta know to understand :down: The converter thing makes a lot of sense, I've not really been exposed to them before but have seen quite a few dyno plots from auto cars which look like that... hadn't really thought too hard about it so cheers for the explain.
Check it out :)
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
