i know this is a bit off topic but, i know of someone, who knew someone who was at the pub of his face when he got into his car he threw his guts up all over the dash and the vomit went down into the heaters ect... didnt matter how much he cleaned it up the smeel never went away, even after pulling the dash apart, never killed the smell, ended up selling the car. Obviously they didnt have the heaters or aircon switched on when they test drove it... very unlikely this is you case but could just well be the case... hehe
you might wanna refill your aircon, a mate had a falcon and it smelled abit when it was empty...
by the way its winter, what you need aircon for?
https://www.sau.com.au/forums/topic/177468-smelly-air-con/#findComment-3241412
lol, dead animal ?
I wouldn't be surprised if there was a dead rat behind the heater system. It's nice and warm.
A Vic member had a rat or something eatting his dog's food in his engine bay, anything can be possible.
https://www.sau.com.au/forums/topic/177468-smelly-air-con/#findComment-3244984
try spraying some house old anti bacterial surface spray disinfectant like 'Pine Clean Glen 20' into the air intake vents for the AC when the AC is on, this will clean all of the shit out and should leave you with a better smelling system. It did work on my old car........use heaps of it but. Make sure you don't get a shit smelling one, i got 'fresh linen'.......smells fantastic :D
https://www.sau.com.au/forums/topic/177468-smelly-air-con/#findComment-3245826
The smell comes from the heater box and evaporator box. After time a build-up of mould and junk builds up in there due to the condensation you get when operating the A/C. Sometimes it can also be due to a blocked A/C drain tube. As im sure the excess water in the drip tray would help to build mould etc. Remove the lower half of the left hand side of tha dash including the glove box and you will be bale to see (from the left), the blower, the evaporator box, heater box. You should be able to remove the evaporator separetly to the other boxes. If i were you (this is what i did and have been told to do) i'd remove the evaporator box and heater box and take them to bit and clean them out with soapy water to remove any grime etc. Another thing that builds up is gunk from the intake air being drawn in by the blower. It gets spread all over the evaporator core, as its the first decent restriction in the air stream. When this happens it can get so bad that you actually get considerably less air flow thru the vents. Check it out.
Regards,
Deren
https://www.sau.com.au/forums/topic/177468-smelly-air-con/#findComment-3249652
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
