not sure if this is the right area to post this but im wondering if you guys can assist.
i just installed a greddy intake manifold, started her up, starts fine and sounds good for about 2 seconds, then it starts missfiring. I also notice water seems to be leaking from the front two top bolts (not including the front nut).
I used a new gasket and coated it in gasket goop before installing so i dont think its that seal thats broken..... any ideas guys?? ive had this car out of action for over two months now and its really startin to pi$$ me off!
Thanks in advance :D
https://www.sau.com.au/forums/topic/177507-water-leak/
If its not missing/leaking and carrying on straight away that could be because the cooling system has no pressure. Once it begins to warm and and pressurise the gasket then starts to leak.
I'd say the 'greedy' plenums flange needs to be checked for straightness.
You don't need to coat the gasket in gasket goop. They go on dry pull it off clean it up (gasket remover spray) and shove it back on with at most a light spray of hylomar. Do check it for straightness while its off. Possibly send it in to be faced 'just' in case.
https://www.sau.com.au/forums/topic/177507-water-leak/#findComment-3242058
Its the second plenum i have tried..... it better not be the head!!
Are they genuine, ive heard of the copies having water leak issues
Also both the genuine and copy can leak between the casting and the metal pipe thats pressed into it that the radiator hose goes onto.
https://www.sau.com.au/forums/topic/177507-water-leak/#findComment-3242426
Okay its off and getting sent to get checked tomorrow.
Is there any chance i may have damaged a water route at the front on the head somewhere putting the new manifold on?
Is there any water channels/plugs near the front of the manifold that i should check?
https://www.sau.com.au/forums/topic/177507-water-leak/#findComment-3242849
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
