Wrecking R33 Skyline Series 1 Colour is Dark Grey everything must go. Car is being wrecked in Penrith some parts available in Hornsby.
Pick up welcome
No Engine or gearbox available.
Engine Parts
gtr diff cv`s hubs 500
Intercooler 400
X Member and Engine mounts to Suit Toyota 1JZ 400
Exhust 4" 400
Tail Shaft 200
Radiator 100
Manual Clutch Pedals Slave Cylinder 150
Radiator 100
Brake Booster 50
Interior
Boost Gauge in instrument cluster 300
Window Switches 150
Electric Window Motors Pair 150
Rear Seat 100
Steering Wheel 100
Door Skin 100
Dash Surrounds 100
Power Windows 100
Carpet 50
Hand Brake 50
Glove Box 20
Rear View Mirror 20
Panels
GTR Indicators 250
Bare Shell 200
Front Fender Panels 200
Boot Lid with Wing 150
Boot Lid 100
Right Door 100
Fuel Tank 100
Standard Indicators (No Chips) 100
Rear Lights 100
Right Mirror 80
Windows 50
Suspension
SSR racing 7kg wheel new rubber 1500
Standard Suspension 300
Standard Wheels 200
Lower Control Arms (Both) 200
Steering Arms 100
hicas lock cost 50
Picture are located here
Pictures
Sold
Bonnet
Front Bumper
Lights
Rear Skyline writing
Edited by Geoff897
https://www.sau.com.au/forums/topic/177600-wrecking-r33-skyline/
Sorry no ash tray
car was manual
I have the boss and steering wheel Front rotors are the standard non slotted rotors
Front bar $150
Ill have to check is the space saver was in the car. will check on the weekend.
All PM replied to, as i have had lots of PM about the coilovers ill check the condition of these on saturday and update this thread.
Geoff
Hey Geoff...
Il grab that Grill off you too.. not the standard one the GTR style one...
Not going to make it there today but how bout tomorrow night .... bout 5.30ish???
btw Happy Birthday :sorcerer:
i was after a complete gtr rear cradle, is that what u have?
where u located
Location in Hornsby and some parts are in Penrith.
PM me you phone number and ill see what i can do.
Thanks Anna
Ill hold the grill for you.. Let me know if you want those Tail lights and Wheels.
