This car has been well looked after and currently has 111,000km
bomex body kit
front strut brace
sun roof
5 speed manual
blow off valve
boost guage
boost controller running 12/15psi
veilside 17'' rims that cost $4,500 new
blitz turbo timer
HKS air pod
chip has been remapped
currently has 160rwkw
3"exaust from turbo
3"high flow cat
magna flow mufler with 5"tip
alpine cd player with pioneer splits
has been lowered with king springs
just been serviced and dynoed at morepower
nismo and hks badges on boot
This is definetly one of the best looking R32's around at the moment,no time wasters please.the asking price is $19,500o.n.o
mobile number:0414925151 email:[email protected]
https://www.sau.com.au/forums/topic/17772-wild-r32/
iam dropping the price to $19000 negotiable,on wednesday iam getting new platinum plugs,timing belt replaced,dyno tune,brake pads and a major sevice.All up costing me close to $1000.This car is starting to become a very good deal for the right person.
https://www.sau.com.au/forums/topic/17772-wild-r32/#findComment-395610
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
