Hey everyone.
Currently got custom made adjustable K-Mac sway bar on the rear of my R33. It is much thicker than stock item and i could feel the difference in terms of the rear being a little more stiffer.
I bought this item 2nd hand from a friend so i got it at a really good price.
This is a little more expensive than whiteline.
So i was thinking of purchasing some thicker ones from the front- either whiteline or cusco
But i wanted to know if its safe to have mis-matched sway bars?
The reason i ask is because each sway bar is a little different in terms of adjustment!!
Also whats the best setting i should have the sway bars for normal street driving?? All at lowest settings? that is not so stiff??
Cheers for the help
Sidd.
ps heres a pic of the sway bar:
Edited by siddr20
https://www.sau.com.au/forums/topic/177763-mis-matched-aftermarket-sway-bars/
Dam it Sidd ! Your the one who beat me to that rear sway bar ! Ha HA !
Seriously though ! Shouldnt be a problem really as the majority of your body roll is controlled from the front so just get a heavy duty adjustable front one the same diameter as the rear.
As to settings thats really personel choice. But I sugest you start at the lowest settings front and back, drive around for a while to get used to it then got up to the next setting and see how it feels.
Hope this helps Dude
Having a stiffer front swaybar will just induce more understeer, so if it applies "too strong" an effect its not as dangerous as running an overly stiff rear bar....unless oversteer is your thing :D
If the price is right, go for it I say. If worst comes to worst you can either sell it, or sell your K-Mac and get the matching rear bar from the same manufacturer.
Since its the front bar, I'd suggest running it as stiff as possible (that way its going to be as understeery as possible, and as any OEM will tell you understeer is safesteer), see if you like it, and then slowly make it softer and softer until you find the optimal balance. Vice versa on the rear bar, if you're trying to adjust relative balances.
... and as any OEM will tell you understeer is safesteer ...
understeer is "idiot" steer. The reason manufacturers build in understeer is that the solution/reaction to understeer is to stomp the brakes - the natural reaction of the less-than-average Joe Citizen driver.
nice bar.
have a look at some of the whiteline kit that are on offer.there are different combos that can be purchased in regards to front and rear swaybars.adj or fixed-22mm-27mm thick solid.i think they may even go thicker.not sure though.
is that bar you have a solid and not hollow?
mine is 24mm front adj and 22mm rear adj.if i remember correctly.they have made a big difference to the way that the car handles.and having adjustabilty there makes that much more difference when you are looking at getting different reactions from the cars handelling performance.also adding camber to the front helps allot for handelling.but wears the tyres out unevenly.
PLYNX- hehe it was up for sale for ages.. no one bought it.. so im like might as well..
Cheers for the replies.. I might just go into K-Mac shop and get their opinions. They only about 20-25mins away
So for a bit of balance for normal street driving, you saying have the front a little bit more stiffer than the rear?
Atm, the rear is at lowest settings..
Edit: I think its a solid bar. Will double check tomorrow.. Does it make a difference tho?
Edited by siddr20
Basically, yes. Swaybars improve response, at the expense of grip. The stiffer you make one end of the car, the more that end wants to push. Stiffen the front, better steering response but more understeer. Stiffen the rear, the back will want to come around faster but you'll find power-down isn't as good as it used to be. Stiffen everything up, four wheel drift time. :thumbsup:
When I put adjustable swaybars in my car with stock suspension, I ran them at full stiff and it was great. When I installed my coilovers (where the spring rates are 2.5x stock), a light touch of the throttle would have me simulating Tsuchiya (actually, more like Lucas Black in the S15). Now I run the fronts full stiff and the rears full soft, although I may peg the front swaybar down a notch and see if my steering is still as responsive while making the car a little more neutral.
Thanks for the help!! Helped a lot..
Being RRP of nearly 400 for this custom made bar, i hope its solid.. Was heavier than the stock item when i put it on.
But didnt really check.. Will do it tonight when i get back from work..
Cheers all
Just to add my 2c and muddy the water a bit.
Yes, you can run bars made by different manufacturers, however, you may find that their range of adjustment is insufficent for you to make them work properly together. You may end up with a car that, once you reach the limit of adjustment (eg front full soft, rear full hard), is still understeering, and so you have no option than to find a bigger rear bar or smaller front bar.
I found whitelines 24/22 combo on my r32 terrible as there was insufficient adjustment to get the car neutral. I had to upsize the rear to a 24mm bar to dial out the understeer completely.
I disagree with scathing a little on the understeer point, i tend to think it's a bit pointless getting bars if you aren't trying to get the balance spot on, tending to a touch of understeer at the limit (atleast initially).
Sorry being lazy to check if its solid or hollow. Will do it today!!
BhDave- Yes you do have a point there. I did think of that before!! I might just go into K-Mac and get another quote, and ask their opinion and see what to do..
will keep you all informed..
cheers
on a lil side note, if your paying $400 rrp then your gettin ripped off, id rather buy an off the shelf cusco one if your gona spend that much, or a whiteline one which would be half the price thereabouts. my 2cents
Nah i didnt pay anywhere near that RRP price.
Just remember that price is from a shop. So they also have overheads etc..
Also remember most sponsers on here probably just buy direct from the brand.. cheaper prices etc..
but lets not get into prices.
Another reason why it cost more is because this sway bar is SOLID, fully adjustable.. made here i think.. anyways.. lets not debate about that..
Whatever you use, DON'T set up a car to understeer. It FEELS safer than oversteer, so I s'pose you feel a lot calmer an instant before you hit the tree.
Work it out yourself. If you're going right, and the understeer is preventing you, and you put on more lock ( and put front wheels more sideways ) you lose more traction on them, and it understeers MORE, etc, Here comes the tree!!!. Oversteer is the opposite. You're instindtive reaction is the right one (work out what's happening with the front wheels) It might feel a bit tail-happy, even if you over correct. Your gut reaction STILL tells you which way to steer. All you need to know is where you'd like it to go, and keep repointing it there, and you're always doing the right thing. Most FWD cars are natural understeerers. KEEP OUT OF THEM.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
