We thought we would check out the bay tonight,,,,what a Scary place....Roads are very narrow and hows about the Bumps,,,,Monty should have had a kidney belt on (he kept looking at me all through there). God is that joint rough. There's almost nowhere you can get on the gas,,,I'll pass on that place,,,Big Time......
Neil.
https://www.sau.com.au/forums/topic/1779-akuna-bay/
wow guys i am blushing.. :D
yeah, i'll give possum bourne a good run down akuna bay and mccars creek road. :D
thats the only road i know my limits on, i have had passengers yell at me down there before. .
Nick, they haven't finished yet i dont think - its a bit hairy because there is dirt on a lot of the corners, and the back tends to get a bit light there.
Paul - next time we go, you can ride with me.
https://www.sau.com.au/forums/topic/1779-akuna-bay/#findComment-33689
Originally posted by PeakRPM
Uuummmm...
There is one place on those roads which can provided lots of fun.
I'm sure I'm not the only one here who knows what I mean....
You'll have to show me one day Peak. I'm all for a bit of fun.
Neil.
https://www.sau.com.au/forums/topic/1779-akuna-bay/#findComment-34805
Carlo,
Im from the chatswood area but always down beaches way.
There was a nasty motorbike acco last Sunday, myself, Kabab and Stu (ZILLA) saw it.... we hoped for a blat down Mccarrs creek road but got stuck behind a rescue unit.... felt like we were behind a pacecar :uh-huh:
Maybe another late night pizza run this Friday night to Newport if any of the others are keen.
Prank? STUGTR? Kabab?
https://www.sau.com.au/forums/topic/1779-akuna-bay/#findComment-38395
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
