Whats your opinion
76 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
As the poll suggests. Ive just bought exhuast and cooler today. the big question being. On a silver car. are people leaning towards getting it out there for the world too see, or does the idea of concealing it partially to make people look twice to notice sound more enticing.
The theme of the car is a clean street car. No bodykit or huge chromies planned.
The other question. What sort of paint would be recommended as odviously some heat will be involved?? Also would a layer of paint normally reduce an IC's ability to lose efficiency??
Edited by l_uk3y
https://www.sau.com.au/forums/topic/177900-your-intercooler-thoughts-visually/
The reason its polished is so that sun light bounces off it, not soaking with heat. Painting it will cause it to not work too well, and heat soak faster then if it were polished. People might like the look of it being out there, but still. Black mesh might be ok, but could take away the cool air being passed through the intercooler when the mesh gets hot.
IMHO leave it polished, and not behind mesh.
zoom or someone similar did a test with black versus polished a few years back and the black cooler (was a GTR cooler) produced cooler inlet charges by a little
This was because the black paint radiated heat better than a silver/chrome surface, which is what you want.
Sunlight isnt gonna cause too much heat soak
hi , ive been thinking about this issue as well. at the moment i have the cooler on show. but recently ive been thinking of puttiing some black mesh in front of it. that way u will still see the silouette of it. either way will look good
go the black cooler, and personally i havent had any issues with a can black job i painted mine with a can and cant fault it havent looked at my inlet temps through my microtech but my mates wrx who also painted his with a can of black saw no change in inlet temps from when it was shinny (monitored through his microtech) during the day it is the same and at night has seen his inlet temp drop into single figures.
the greddy coolers have a special anti corrision treatment on their V-SPL and R-SPL coolers that is as functional as it is pretty (polishes up nice and still radiates heat very well)
better yet, put an hks stencil on it, imagine the power gain then! personally i like the wank factor of the silver cooler, then again i have a black car, so a black cooler would blend right in. i really like the look of a clean silver SII with a cooler mounted nicely behind the front bar, but that might be just me
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
