Theres a problem with my brakes in my Skyline, which i bought 2 weeks ago. 1st week of running it was fine, but now at slow speeds the breaks make a very loud screeching sound. I will hopefully be able to take it to the ppl who had a look at the car before sale to make sure everything is OK. Does anybody know what the problem could be?
https://www.sau.com.au/forums/topic/177990-breaks-problem/
most probably just worn pads. The screeching noise is there by design to advise you the pads need changing. If your thinking about upgrading your rotors ( say to slotted ) now is an idea time to change them , as your going to need to remove the calipers to put the pads in
https://www.sau.com.au/forums/topic/177990-breaks-problem/#findComment-3248566
Hmm i had the same problem with my old 33, i put bendix ultimates in they were so noisy, mechanics could not quite them down, so i had to change them to a softer compound.
Thanks. hmm that must be the problem then, so a softer compound i take it is working fine then?
https://www.sau.com.au/forums/topic/177990-breaks-problem/#findComment-3249286
Softer compounds will also generate shitloads of dust for your rims. Sometimes shit (such as tiny stones etc) get in between your rotors and pads which will also generate noise, just give it a quick clean with a big pressure hose or something. It helped on my brothers rexie.
https://www.sau.com.au/forums/topic/177990-breaks-problem/#findComment-3249893
Ultimates are dusty as anything...
https://www.sau.com.au/forums/topic/177990-breaks-problem/#findComment-3250344
Thanks for all the responses guys..
The pads are new, so its not due to any wear/tear, just that they are racing pads with a hard compound. I could get the softer compound, yet it will get dusty as ppl have pointed out, so yeh.
I decided to give it to the mechanics, they said they will sand it and apply some goo and said that it should reduce the noise, yet there is no guarentee of it not reccuring in the future.
Anyways im glad to know that it is a common occurance and that there is nothing wrong with the brakes. :P
https://www.sau.com.au/forums/topic/177990-breaks-problem/#findComment-3251004
Good luck hope you sort it out. :)
https://www.sau.com.au/forums/topic/177990-breaks-problem/#findComment-3251182
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
