To th best of my knowledge its only computers like Motec M800 and Autronic SM2 that have individual cylinder tables.
Unless you are lucky enough to have such a computer i think your best bet is to get your injectors cleaned and flow tested, and put the highest flowing injectors in cylinders 5 & 6
Gav, where did you here this, as I think there's merit in the 5 & 6 running lean/hot when the RBs are pushed.
I have bought big turbo and have stalled its install to make sure I have good fuel supply to rear of motor. The delay is due to a couple of cars very recently here in SA have blown no. 6 pistons and also no 5 & 6 upper studs on my exhaust manifold have sheared off indicating to me greater heat cycling.
The issue I think is high pressure drop across the fuel rail at elevated fuel pressures and since it's a front feed system the end of the rail might see less fuel pressure.
Many aftermarket rails have centre feed, equalling out the pressure a bit.
51jay, I had a look at my motor during lunch and I had it wrong re fuel supply point. The fuel comes in from the back as well (ie closest to no 6 cyl) not the front.
Spoke to a Chem. Engineer here at work and he said maybe there is higher pressure at no. 6 piston causing cavitation at the injector and consequently less flow. ????
'Tyndago' off the SDU forums drag races a bit and plays with GTRs in the US. He states there that he spoke to some japanese GTR guru (cant remeber name) and that he said go highest flowing injector to 6 then down to lowest at 1. So this is in line with the 6 and 5 running a bit leaner - might be worth flow testing your injectors before fitting them.
Hi guys, the main problem is the airflow in the GTR inlet manifold is biased towards no 6 and to a lesser extent no 5. This only starts to occur when they get up in the power output, over 280 rwkw seems to be the area.
It extra airflow isn't much, between 2% and 3%, which is enough to cause detonation on those 2 cylinders when the other 4 are fine. This of course only happens in an engine tuned very close to A/F ratio tolerance. So you can have very low detonation warnings, and think the engine is OK. But all the detonation is on 1 or 2 cylinders, not spread across the 6.
When you flow test 6 injectors you always find one or two that flow a little more than the others. This is an example of the set in our RB30/26 powered GTST
1 560 cc's
2 560 cc's
3 560 cc's
4 565 cc's
5 570 cc's
6 575 cc's
So, no 6 flows 3% more than no's 1,2 & 3. This is more than enough to allow for the extra airflow and ensure no leanness in no 6. Similarly no 5 is also safe.
As Gav said, if you have an ECU with individual cylinder trim (eg; Motec M48 Pro) then you can allow for this by richening up no 6 and no 5 (in comparison to the other 4 cylinders). If your ECU does not have this facility, then simply sticking the highest flowing injectors in 6 and 5 is a simple solution, albeit not as accurate.
The accurate way to test this is by having provision for a lambda sensor in each exhaust manifold primary pipe. That way you can measure the A/F ratio of each cylinder individually. Measuring temperature of the exhausts gas (or the primary pipes themselves) is a good substitute.
I have not seen this airflow biasing problem in standard RB20/25 inlet manifolds, as they appear to have very even distribution. It is quite possible that aftermarket manifolds with the throttle body at the front of the plenum may also suffer from this problem. Ditto standard manifolds that have had the throttle body moved. I have not tested this in practise, but it would seem most likely.
There is also an argument that says no 6 and no 5 are the furthest from the radiator and water pump and therefore may run hotter. This would exacerbate any leanness in those cylinders. Richening them up would also help this problem.
Hope that helps
Sydneykid, sounds feasible re RB26 manifolds when pushed.
So if the problem is compounded by no. 5 & 6 location relative to the radiator & water pump (that goes for any RB series motor), is there any merit in upgrading the cooling system when stretching RBs to ensure longevity?
If so, what would be a realistic stepwise uprgade path? Higher capacity water pump? etc etc
For background I have RB25 + very soon bolts-ons to obtain 250-260rwkW and want to make sure pistons last at least a little while.
adam32, yep a few of us here have done that already (for about a year now), I also removed the rubber strip to increase gap width. Not sure how effective it is as I only recently noticed the exhaust manifold upper studs on 5 & 6 cylinder had fallen off!
Hi Guys, the problem is not one of "absolute" temperature, it is "differential" temperature. The sort of stuff suggested may well lower the overall temperature of the engine, but it won't make no 6 or no 5 run the same temperature as the other 4.
That's the basic problem, so you have to do something to cool only those 2 cylinders and richening up the mixtures is the best/easiest way. If the ECU supports it, you could retard the ignition timing a little, that will also assist.
Hope that helps
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
