Hey all.
i installed a drift bov today with plumb back or atmo i could choose either way but i choose atmo..
Since then its been running like crappolia..
Is there anything like a cpu upgrade or soemthing to fix the problem?Or is it just something i have to deal with
thanks
https://www.sau.com.au/forums/topic/178380-problems-after-installing-a-bov/
Hey all.
thanks
If its venting to atmo then you will run rich and your car will occasionally stall. Atmo BOVs on Skylines can be a bad mix. You can fix it up, DAFS.
happens to most people who install the atmosphere venting bov's. After a while you will learn how to adjust your driving so it doesn't stall. All i do is blip the throtle when coming to a stop ect. Do a search on the forum about this, been covered alot of times, you may find some use full tips.
Unfortunately blow off valves and skylines as some other member explained are not a good mix. I even use to have a GFB stealth that you get to adjust how much air is vented and how much is kept and car still didnt feel the same and idle was terrible. I know its not what you want to hear but if you want to have a car that runs well then install your stock bov.
i still have my stock plumback on my s1, no problems as in running, sometimes when letting clutch out a little to move forward in places like drive through with a little bit of throttle then go to put brakr on and clutch in cars idle does drop to close to a stall but then picks up again, only problem i have in regards to stalling hope this helps
Stalling when having a atmo bov installed is a really common thing. The reason it happens is because the afm detects the air going into the engine and puts more fuel in to burn the air, but the air is not getting into the combustion chamber, it's going out of the bov. I hope that made some sense.
As far as I know, it's something you just have to deal with if you're got a bov installed.
some people here adjust the idle just a little higher than stock, others just learn how to drive them like when you're about to stop change gear or clutch in when the idle is near idle speed. Or you rev it a little before you stop.
The main issue with atmospheric BOV's is the AFM... Once air has gone past that it is accounted for by the computer, any difference an atmospheric BOV will cause means there is air accounted for, but not being used. With MAP sensor its a different story as it reads manifold pressures not airflow before the turbo. With the plumb back system the air goes back through the turbo or the afm keeping it all in the circuit of the airflow so the ecu can adjust according to the afm readings. Some cars just handle it better than others, my mates 32 used to be perfectly fine with big turbosmart BOV's but my mates 33 would stall all the time with a Blitz one and then the HKS one.
Liam
Edited by FordyR31
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
